Author Topic: Skinny's/Pizza Cutter's/Expo/etc... Thread  (Read 88309 times)
0 Members and 4 Guests are viewing this topic.
  • 4BangerJP.com® Donator
Re: Skinny's/Pizza Cutter's/Expo/etc... Thread
« Reply #30 on: January 24, 2011, 10:29:53 AM »
On AC, I had been thinking that too.  Maybe AC and 4:88 gearing with the 31s I have now.   But more likely the 4:88 gearing.  Once I do, my Jeep could forever be sitting on 31s, since i'll get used to the driveability with the 4:88s.
By the next tire change, I might just stick with 31s for my existing Jeep, then buy a second jeep -- maybe a 4.0 YJ or TJ 5spd that's already built to run with 33s or 35s.
« Reply #31 on: January 24, 2011, 09:11:32 PM »
Well, yes and no.  I'd probably do 4:88s on 31s on the 4banger, then get a 4" lift, etc. and 33MTs for next tire change with that gearing, then maybe see if i could, at that point, squeeze a little more out of the engine (electric fan, headers, intake manifold grind)
« Reply #32 on: January 24, 2011, 09:31:45 PM »
Unless you're going to do some harder trails you really don't need 33's.  4" with 31's will get you pretty far especially with a locker.  Tuck the transfer case up and add some engine skids and you'll be good.  If you think you're hurting for performance with 31's on there then you'll have a rude awakening with 33's.  The lift will hurt you as much as the tires though.
BTW: I measured my 15x6's.  They're 5.5" BS with a +50mm offset.
« Reply #33 on: January 24, 2011, 10:33:02 PM »
Ugh, some guy near me is selling Moab's with the stock tires for $300...  Very tempting!
« Reply #34 on: January 25, 2011, 04:59:08 AM »
The harder trails were the idea for the 33s down the road
« Reply #35 on: January 25, 2011, 11:00:55 AM »
Then I'd do skinny 33's and not 12.5's.  Most trails should be doable with 31's and some good driving.  33's if you want a little easier time.
« Reply #36 on: January 25, 2011, 04:47:35 PM »
Here are some specs for the BFGoodrich KM2's in a few of the common sizes that we'd see on Jeeps.
   Size                        215/75R15         235/75R15         31X10.5R15      33X10.5R15      33X12.5R15      35X12.5R15
   Max Load                  1765 lbs.            1985 lbs.         2270 lbs.            2600 lbs.         2205 lbs.         2535 lbs.
   Max. Inflation Press.       50 psi             50 psi            50 psi                  50 psi            35 psi            35 psi
   Tread Depth                  18/32"          18/32"         19/32"                  19/32"               x                  20/32"
   Tire Weight                  34lbs.             40lbs.          45lbs.                  49lbs.                  58lbs.         61lbs.
   Rim Width Range            5.5-7"              6-7"          7-9"                  7-9"                  8.5-11"         8.5-11"
   Meas. Rim Width            6"                  6.5"            8.5"                  8.5"                     10"             10"
   Sect.Width                  8.5"                  9.3"            10.5"               10.5"                  12.5"            12.5"
   Tread Width                  6.7"                  7"               7.7"                  7.7"                     9.8"            9.4"
   Overall Diam.                  27.9"                29.1"         30.8"               32.8"                  32.8"            34.8"
   Revs Per Mile                  746                  715            675                     634                  634               598
« Reply #37 on: January 26, 2011, 02:59:50 PM »
Here's some other FAQ's I've found.  Supposedly Ford Explorer/Ranger/Mountaineer wheels have an offset of +12mm.
Here's a list of all makes that seem to fit a Ford Ranger.  They don't say anything about BS or Offset though.  They all share the 5 on 114.3mm (aka: 5 on 4.5") bolt pattern though.  Also, 1998+ 4x4 Ranger's have hubcentric wheels so I doubt they will fit on the Jeeps axles without some milling or a sanding drum as wheels on Jeeps are lugcentric so the center bore doesn't have to be as precise.  I would also think many of the newer cars are similar.
Make    Model    Years
Acura    Legend    1991-99
   RSX    *
AMC    Most models (exc. Jeep)    1940-89
   Ambassador    1960-83
   American    1960-83
   AMX    1960-83
   Classic    1960-83
   Concord    1960-83
   Eagle (4×4)    1980-89
   Gremlin    *
   Hornet    1960-83
   Javelin    1960-83
   Marlin    1960-83
   Matador    1960-83
   Pacer    1960-83
   Rambler    1960-83
   Rebel    1960-83
   Spirit    1960-83
   SX4 (4×4)    1980-89
Chrysler/DeSoto    All full size RWD cars (exc. Imperial)    1937-89*
   300    1958-88
   Concorde    1993-99
   Cordoba    1975-83
   Custom    1958-88
   Fifth Avenue    1985-89
   Imperial    1974-83
   Le Baron    1978-81
   New Yorker    1958-88
1993-99
   Newport    1958-88
   Sebring    1995-99*
   Town & Country    1958-88
Datsun/Nissan    1600-2000    1965-73
   300ZX, 200SX V6 (some)    to 1989
Dodge    All full size cars    1937-89*
   A100    1963-71
   Aspen    1973-80
   Avenger    1995-99
   B100    1972-86
   B200    1974-85
   Caravan    1987-99
   Challenger    1957-77
   Charger    1957-77
   Coronet    1957-77
   D100    1972-86
   D200    1974-85
   Dakota    1987-90
   Dart    1973-80
   Demon    1973-80
   Diplomat    1978-89
   Interpid    1993-99
   Magnum    1957-77
   Mirada    1975-83
   Monaco    1957-77
1990-92
   P200    1974-85
   Polara    1955-77
   Ram 150 (ex HD)    1972-86
   Ram 250 (ex HD)    1974-85
   Ram Charger    1974-85
   Sport    1973-80
   St. Regis    1975-83
   Swinger    1973-80
   Volare    1973-80
   W100    1972-86
Eagle    Talon    1989-97
   Vision    1993-97
Ford    All full size cars    1949-72
1979-85
   Aerostar    1986-97
   Bronco II    1983-90
   Crown Victoria    1979-Current
   Country Squire    All Years*
   Custom    1965-85
   Explorer    1991-Current
   F-100    1980-85
   Fairlane    1962-79
   Falcon    1968-71
   Futura    1965-85
   Glaxie    1965-85
   Granada    All Years*
   LTD    1971-80*
   Maverick    1971-80
   Monarch    All Years*
   Mustang    1965-73
SVO 1985-86
1994-Current
   Mustang II    1974-78
   Probe    1989-98
   Ranchero    1968-84
   Ranger    All Years
   Thunderbird    1955-71
1977-79
   Torino    1971-80
Hudson    All    1948-56
Jeep    Cherokee (XJ)    1984-01
   Wagoneer (XJ)    1984-89
   Brairwood (XJ)    1984-91
   Comanche (MJ)    1984-92
   Grand Cherokee (ZJ)    1993-98
   Wrangler (YJ)    1987-95
   Wrangler (TJ)    1997-06
   Liberty (KJ)    1902-present
Lexus    SC430    *
   Other Lexus    *
Lincoln    All    1970-72
1980-89
   Aviator    1902-Current
   Continental    1986-Current
   Mark III-VII    All Years*
   Town Car    All Years*
Mazda    323    1981-89
   626    1987-99
   B-Series    1994-Current
   GLC    1981-89
   Millenia    1994-97
   MPV    1984-95
   MX6    1986-99
   Navajo    1991-95*
   RX7    (any 5 lug car)
Mercury    All full size cars    1952-54
1961-72
1979-85
   Capri    All Years
   Colony Park    All Years*
   Comet    1971-80
   Cougar    1967-79
   Grand Marquis    All Years*
   Marauder    1902-Current
   Meteor    All Years*
   Monarch    1971-80
   Montclaire    All Years*
   Monterey    All Years*
   Montego    All Years*
   Parklane    All Years
   Villager    1989-97
Mitsubishi    3000 GT    All Years*
   Diamante    1991-02
   Eclipse    1990-02
   Galant    1999-02
Nissan    240SX    1995-99
   300ZX    1990-96
   Altima    2002*
   Maxima    1989-02
Plymouth    All full size cars    1937-89
   Barracuda    1970-74
   Belvedere    1957-80
   Duster    1973-80
   Fury    1957-80
   Laser    1989-96*
   Satellite    1957-80
   Savoy    1957-80
   Scamp    1973-80
   Trail Duster (ex 4×4)    1974-85
   Valiant    1973-80
   VIP    1957-89
   Volare    1973-80
   Voyager    1988-95
Pontiac    Tempest, LeMans    1961-63
Studebaker    All    1951-66
Toyota    2WD P.U.    1969-89
   Camry    1992-99
   MR2    1991-99
   Previa    1991-95
   Supra    1986-91
Volvo    122    All Years*
   1800    All Years*
« Reply #38 on: January 27, 2011, 08:21:19 PM »
Been browsing POR.  It's funny how you're a noob if you're not rolling on 37's or bigger.  in the picture thread everone is trying to top the next guy.
Found a pic of a '94 with 31's.  I didn't realize the 6-Spoke wheels were used well into the 2000's.
« Reply #39 on: January 27, 2011, 08:34:01 PM »
:uhoh: the ones in the picture have 5 spokes  :uhoh:
« Reply #40 on: January 27, 2011, 08:36:34 PM »
Yeah, they're 5-Spokes.  The 6-spokes weren't available on the TJ just XJ.
Here's a 6-spoke YJ
« Reply #41 on: January 27, 2011, 09:23:55 PM »
4 inch lift and 36's
I found it in this thread. I skipped around a bit since it's a huge thread. There might be more in there on stock wheels.
http://www.jeepforum.com/forum/f12/how-will-my-jeep-look-xx-tires-x-x-lift-109455/
« Reply #42 on: January 27, 2011, 09:35:11 PM »
Here's a 6-spoke YJ
i like the 6 spoke better. I think they would look nice flat black rather than silver.
« Reply #43 on: January 27, 2011, 09:51:20 PM »
Wow, those are huge.
I'm torn between the 5 and 6 spokes.  The 5 spokes would be easier to clean since it's a flush face.  The 6 spokes are a bit more retro.
I've been tempted to go down to 31's since there are so many more choices in tires BUT that's a big jump.
« Last Edit: January 27, 2011, 09:55:54 PM by Jeffy »
« Reply #44 on: January 27, 2011, 09:54:20 PM »
I like the look of the larger windows of the 5 spoke.
