Author Topic: 16" Rims?  (Read 1537 times)
Offline lokitim
16" Rims?
« on: January 24, 2011, 02:00:54 PM »
I am looking at a set of 16" rims, with 4" offset - $100, do you think I will have any problems running 33x12.50's?
1993 YJ, 4cyl, AX15 5spd,  J20 3/4 ton axles, SOA with stock springs, disc brakes on all fours, hi-steer, flat tops,33x12.50 General Grabbers on beadlocks,Warn Front Bumper, Smittybilt w/swing away tire mount rear bumper, custom Hi-Lift Mount, Bedliner interior & body sides, Flush mount tail/backups
Re: 16" Rims?
« Reply #1 on: January 24, 2011, 02:54:22 PM »
Well, 4.5-4.75" is considered good if you want the tires to stay tucked but not rub.  12.5's will stick out a bit more with 4" but not too bad.  Maybe 1.5"-2" past the flare.
