Author Topic: High flow cat opinions  (Read 3842 times)
« on: January 27, 2011, 02:13:38 PM »
Im looking to replace my existing stock cat. The thing is pretty much shot. Id like a high flow cat to match the high flow exhaust i have (banks header/cat-back). Im not too sure about the available brands. Im considering Random tech's High Performance for $280. Ive read a few reviews that said they are pretty good.
Any opinions on good high flow cats?
will this make the exhaust any louder or help cut the noise? Dont want it any louder haha.
chitchc2
Re: High flow cat opinions
« Reply #1 on: January 27, 2011, 02:50:36 PM »
This may help out:
http://www.installuniversity.com/install_university/installu_articles/cat_flow_test/cat_results_discussion11.122001.htm
If I'm reading this correctly the author is stating that optimal performance is obtained at 2.2 cfm overall exhaust flow per hp (now he doesn't clarify where to measure that hp but I suspect he means crank hp and not brake)
If you assume that the average standard CAT flows at 280 CFM then it would be "optimal" for a 127 crank hp engine.
What does all that mean? It means that you would only benefit from a higher flow CAT if:
1) You have enough modifications on your AMC 150 to get it over 127 chp
2) The rest of your exhaust system isn't creating a flow restriction greater than the CAT
My guess is that any after market CAT that is "High-Flow" is suitable for our 4 bangers unless you have major engine modifications
One more note: I'm not an expert on this at all, this is just what I found while researching what to do with my TJ.
« Last Edit: January 27, 2011, 02:51:51 PM by chitchc2 »
« Reply #2 on: January 27, 2011, 03:25:56 PM »
This may help out:
My guess is that any after market CAT that is "High-Flow" is suitable for our 4 bangers unless you have major engine modifications.
interesting point. now the other issue is quality. i want something that has a good reputation and will last.
« Reply #3 on: January 27, 2011, 03:55:25 PM »
Forget Random Tech.  Look at Magnaflow/Carsound.  The bolt on cat is $150 less.  You could go cheaper with a universal but I like the bolt-on's.  Several members are running the Magnaflow.
« Reply #4 on: January 27, 2011, 04:27:18 PM »
Jeffy i think i remember you saying that a hi-flow cat would quiet down the exhaust. is the magnaflow a high-flow?
« Reply #5 on: January 27, 2011, 04:31:24 PM »
A Cat will quiet the exhaust.  Run it as a straight pipe then put the cat on and you'll quickly realize how much nicer it is with the cat on.  Yes, the magnaflow is a hi-flow.  Do a search on 'carsound'.
« Reply #6 on: January 27, 2011, 04:43:19 PM »
thanks Jeffy. Magnaflow it is.
« Reply #7 on: January 29, 2011, 12:42:05 PM »
magnaflow doesnt make a hi-flow cat for a 98 2.5l. they make them for 00 and up.
« Reply #8 on: January 29, 2011, 01:21:33 PM »
It's not that they don't make one.  It's just that it's a universal.  (99005HM)  This is because the stupid cat is welded on with no joints.  They aren't able to be replaced as easily.  You can see for the 4.0L, that they had to replace the whole down pipe as well. Jeep changed this in 2000.
« Reply #9 on: January 29, 2011, 07:00:49 PM »
I'm one of those; no problem with mine so far except I had to welded up to the exhaust pipe because it came loose on me once (and I am not a big fan of EXTREMELY noisy Jeeps!)
« Reply #10 on: January 29, 2011, 10:30:54 PM »
same here.
  • 4BangerJP.com® Donator
« Reply #11 on: February 01, 2011, 10:09:26 PM »
Somebody's cat doing a stand-up "high-flow"  Had opinions before he got "fixed."
The Car sound/Magnaflow I got last year based on recommendations here seems like it worked out pretty well.  I got mine at O'Reillys, and in California, for only around $200.
« Last Edit: February 01, 2011, 10:30:51 PM by chrisfranklin »
