Author Topic: 04 2.4l cooling fan  (Read 4318 times)
poortech
04 2.4l cooling fan
« on: February 15, 2011, 02:33:59 PM »
hey guys. i was wondering if anyone know where i can find an aftermarket replacement cooling fan. i dont want to get some cheap universal i want an exact replacement. i called the stealership and they want 579.00  :yikes: thanks in advance
Re: 04 2.4l cooling fan
« Reply #1 on: February 15, 2011, 03:49:52 PM »
You are talking about the cooling fan clutch, correct?
rock auto has the Omix-ada replacement for about $45 http://www.rockauto.com/catalog/moreinfo.php?pk=2770654
« Reply #2 on: February 15, 2011, 05:38:03 PM »
I assumed his was electric ?
thats insane  if they price it out that high for a clutch fan
« Last Edit: February 15, 2011, 05:39:44 PM by Torch_Ind »
poortech
« Reply #3 on: February 15, 2011, 06:12:09 PM »
i dont have a mechanical fan. its a 2 speed electric fan that im starting to get the feeling like mine was the only one made and thats why the replacement sitting on the self at the deal is 579 dollars.
« Reply #4 on: February 15, 2011, 06:34:55 PM »
humm weird there must be a aftermarket for it
« Reply #5 on: February 15, 2011, 06:54:46 PM »
i looked at '03, '04 and '05 and couldn't find an electric fan option that's why i thought it's the clutch.
what's the part number on the fan? is it Chrysler labelled?
« Reply #6 on: February 15, 2011, 07:05:45 PM »
2.4 uses an electric fan
poortech
« Reply #7 on: February 16, 2011, 06:48:31 AM »
the dealer says the part number is 55036797ab
« Reply #8 on: February 16, 2011, 09:18:34 AM »
that one i cannot find, weird thing is i can find OEM replacements online for XJ, JK, Liberty but not for TJ so I'm out of suggestions
for example here's the Liberty '02-'07 2.4L oem p/n 55037659AA http://www.omix-ada.com/jeep-parts/productInfo.asp?itemNo=55037659AA
or the XJ oem p/n 52028337AC http://www.omix-ada.com/jeep-parts/productInfo.asp?itemNo=52028337AC
JK direct fit replacement (oem p/n: 55056642AB) http://www.drivewire.com/search/?Ntt=RB620055 or here http://www.car-stuff.com/2009jeepwranglerradiatorfan.htm
but those are different (not suggesting you should use as a replacement) - the TJ seems to be a dealer only item, i couldn't find 55036797ab in any cross reference catalogs
« Reply #9 on: February 16, 2011, 10:25:44 AM »
the parts place here said they would need a vin number to have any chance. other then that it comes up as clutch fan like sharp said. other then the liberty?
Offline mrcabinet
« Reply #10 on: February 16, 2011, 10:33:24 AM »
Check out wrecking yards. I looked at one on an '04 that was a rear end total with 10k on it. I thought about using that for the efan conversion but went another direction. They only wanted $50 for it. I found them on car-part.com as well.
poortech
« Reply #11 on: February 16, 2011, 12:31:30 PM »
thanks for the help guys. as for junk yards there arent any here with a 2.4l in the jeeps they have.
