Author Topic: What's the best diff fluid?  (Read 9027 times)
RT
« on: February 21, 2011, 11:04:52 PM »
Should I get the good stuff (royal purple, redline, valvoline) or just get the $4 crap at autozone......plus what's the better weight 80-90 or 75/85-140. I'm in New Mexico so temperature's not an issue for lubrication.
Re: What's the best diff fluid?
« Reply #1 on: February 22, 2011, 07:24:10 AM »
cheep I would pick if your in high heat area.. at the most pick the cheapest synthetic blend
RT
« Reply #2 on: February 22, 2011, 08:58:39 AM »
Well, I've been having a lot of drivetrain whine.....probably just a jeep thing but idk...the diff fluids grey so I'm going to see if that's it. What would shut it up better, synthetic or mineral?
« Reply #3 on: February 22, 2011, 09:16:03 AM »
chances are if it's water or debris in the fluid "making it gray" it may make a difference in noise just putting in anything clean.. it's that or you have a bearing going or ring and pinion whine !!
RT
« Reply #4 on: February 22, 2011, 02:57:44 PM »
They're was some nasty sh*t in there! lol, it was weird, there weren't any 'shavings' but the oil was 'glossy' and shiny. I ended up putting $4 80-90 and lucas stabilizer in it and it actually drives better. What sucks is that I only had a couple thousand miles on that oil, I guess I have to change it seasonally?
« Reply #5 on: February 22, 2011, 04:55:56 PM »
I do seasonally but I do a lot of under water and soupy mud.. I usually swap my fluid for winter and then run it till winter or change it if I got it contaminated..
lets just hope whatever reason your fluid was so bad it didn't cause bearing damage.
« Last Edit: February 22, 2011, 04:56:49 PM by Torch_Ind »
RT
« Reply #6 on: February 22, 2011, 08:18:14 PM »
I had a rebuild because of melted spider gears where all the bearings were replaced along with they spideys 6 or 7 months ago...maybe just breakin? idk
« Reply #7 on: February 22, 2011, 09:57:44 PM »
how did you manage to melt the spider gears? they don't move too much under normal circumstances.
No Luck
« Reply #8 on: February 22, 2011, 09:58:44 PM »
Mobil-1
RT
« Reply #9 on: February 22, 2011, 11:19:21 PM »
i got water in the differential and then drove cross country at 85 mph, they were nice and toasty! lol lots of steel shards and really deep ass pits in the spider gears, the shards shreaded all of the bearings and the vibration hollowed out my carrier
RT
« Reply #10 on: February 24, 2011, 11:24:10 PM »
anyone else have a catastrophic experience like this lol
« Reply #11 on: February 24, 2011, 11:43:12 PM »
i blew couple of teeth on the ring and on the pinion as well.
RT
« Reply #12 on: February 24, 2011, 11:54:37 PM »
how'd you manage that
« Reply #13 on: February 25, 2011, 03:34:53 AM »
it happened on the hwy, however when i took it apart there seemed that the preload on the pinion was gone (it had some play in it) so the gears didn't mesh properly and caused wear on the teeth.
RT
« Reply #14 on: February 25, 2011, 06:36:29 PM »
This is the first time I've changed the fluid since I got the new spideys, bearings, and carrier....is it possible i'm just seeing resin/breakin material in the fluid  :fitz:
