Author Topic: YJ Pitman arm  (Read 2246 times)
fryedaddy
YJ Pitman arm
« on: February 22, 2006, 02:11:53 PM »
I was wondering if anyone knew if the pitman arm from a yj would fit on a cj steering box. I have a 92 Yj with manual steering and found and bought a CJ box because I found a good deal in it. are they interchangeable?
YJ Pitman arm
« Reply #1 on: February 22, 2006, 03:19:28 PM »
Manual and P/S use differnt pitman arms so if that's what you're planning then it won't work.  If they are both manuals then it might work.  Although I'm not sure if the index key is in the same location.
getstucksome
YJ Pitman arm
« Reply #2 on: February 25, 2006, 11:14:13 AM »
if the index key isn't in the right spot you can just cut the key apart and put the arm on at whatever degree you want.  i had to do that with my wj arm.
you just need to make sure they have the same spline count i would think, or else it wouldn't line up a tall
