Author Topic: 30rh lock converter  (Read 2618 times)
wrench0001
30rh lock converter
« on: March 16, 2011, 07:54:19 PM »
just swapped my ax5 for a 30rh  (904)runs great  but convert in not locking up i swaped the ecu for the auto found the location for the relay (middle of firewall ) and installed one still not locking up does any know if there is a fuse  ?.
i used power form  a spare switch to the lock up wire in the relay location blue wire with tan stripe and works great .
any help would be great ,thank you in advance
  • Chief Squirrel BlowerŽ
Re: 30rh lock converter
« Reply #1 on: March 16, 2011, 08:01:36 PM »
check what the FSM says for your Jeep (you can probably find it on morris4x4.com, they have a online service manuals section) - you should mention what year and model (if other than Wrangler) - i can't help since with the auto transmission but for others that might be able to advise on the issue
wrench0001
« Reply #2 on: March 16, 2011, 08:07:38 PM »
sorry forgot 95yj 2.5l with 94 yj 30rh looked through  the Haynes manual could not find any thing will look in the fsm
« Reply #3 on: March 16, 2011, 08:47:23 PM »
i'll have a look in the manual to see if i can find something, i have a 95 with manual transmission.
« Reply #4 on: March 16, 2011, 09:06:40 PM »
Quote
TORQUE CONVERTER CLUTCH (TCC) SOLENOID
AND RELAY
The TCC solenoid is only used on three-speed automatic
transmissions. The Powertrain Control Module
(PCM) operates the TCC solenoid by energizing
the TCC relay.
Circuit G50 from fuse 5 in the Power Distribution
Center (PDC) supplies voltage to the coil side of the
TCC relay. When the PCM provides a ground path on
circuit K54, the relay contacts close.
When the relay contacts close, they connect circuit
A14 from fuse 1 in the PDC with circuit T22. Circuit
T22 supplies battery voltage to the case grounded
TCC solenoid. Circuit K54 connects to PCM cavity
54.
HELPFUL INFORMATION
˛ In the RUN or START position, the ignition switch
connects circuit A1 from fuse 4 in the PDC to circuit
A21.
˛ Circuit A21 powers fuse 5 in the fuse block.
˛ Circuit G50 also connects to the engine data link
connector, Automatic Shut Down (ASD) relay, and
fuel pump relay.
so it looks like there are 3 fuses of interest all in the PDC by the battery (fuse 1, 4 and 5).
there is something else mentioned there which you'll have to check, they say that the same circuit which controls the t/c lock relay is the one that controls the upshift lamp on the dash - not sure if that means that the harness is different or if that circuit has a dual purpose (you could tell though if your upshift lamp lights up and your t/c does not lock it means you'll have to reroute circuit K54 that comes off pin 54 on the PCM to the relay)
Quote
UPSHIFT LAMP
On vehicles equipped with a manual transmission,
the PCM grounds the up-shift lamp on circuit K54.
Circuit K54 connects to cavity 54 of the PCM.
I looked at the diagram and seems that are both wired in, so if your upshift lamp was working before and now it also lights up that is your t/c solenoid lock command from the PCM - if your t/c does not lock it means the relay is not powered (since you already tested it with a jump wire if i understood correctly from your initial post).
hope this helps.
« Reply #5 on: March 16, 2011, 09:50:18 PM »
It won't be a fuse since those 3 are used for other purposes as well (so the Jeep won't run if that was the case)
you could also check the voltages on the relay - these are the colors of the wires on that socket and purpose
 - white with yellow stripe = switch +12v from the ignition contact (with key in run position should have +12v) from fuse 5 in the PDC
 - red with white stripe (thicker wire gauge 16) = live +12v (hot wire at all times from Fuse 1 in the PDC)
 - orange with black stripe = PCM solenoid control to the TCC relay provides ground (also provides ground to the upshift lamp in the dash) comes from pin 54 on the PCM connector
 - dark blue with tan stripe =  goes to the TCC solenoid at the transmission.
wrench0001
« Reply #6 on: March 17, 2011, 03:24:43 AM »
i know the up shift light does work i was in  2nd gear manually shifting the auto and up shift came on till i went into drive and the fsm shows up shift and tcc are spliced together at the relay socket i will have to check i might just have a corroded relay socket been sitting there empty for years .do have to say love the auto 31"tires with the 410 gears was worried i was gonna feel a real loss in power.thank you for the help and replies will look into it more after work
wrench0001
« Reply #7 on: March 17, 2011, 06:01:38 PM »
problem solved .it was the new shifter was out of adjustment run great .thank you for all the help
« Reply #8 on: March 17, 2011, 06:06:42 PM »
glad you figured it out.
what do you mean was out of adjustment? just for my information if you don't mind.
wrench0001
« Reply #9 on: March 18, 2011, 03:34:16 AM »
i had installed the hurst promatic 2 shifter while doing the swap directions tell you 1 gear on shifter trans arm all the way forward adjust cable till cable end drops in to trans arm well i was about 3/8 out of adjustment so on the shifter netural was drive didnt notice it was little hard to see indicator now   all lined up drives great and can see indicator
