Author Topic: Dynatrac High-Clearance U-Bolt Kits and sway bars...  (Read 4895 times)
« on: April 03, 2011, 02:32:13 PM »
OK, so I got me a set of Dynatrac High-Clearance U-Bolt Kits for each axle.
The rear is already in place, but the front is not.  The first issue I had with them is that on BOTH sets, the threads on one side of one of the bolts is simply not long enough.  I have a thread die, so I'm planning on correcting this shortly, but the other issue I have (and the reason I have not yet installed the front) is that there is nowhere to install the sway bar.  Should I just weld a bolt in there and cut the links to match the new reduced hight?
Also, the bolts are SUPER long, so you got to cut them down our even the long ratchet sets will not reach the nut, but nothing and angle grinder cannot fix...
Re: Dynatrac High-Clearance U-Bolt Kits and sway bars...
« Reply #1 on: April 03, 2011, 03:04:18 PM »
the threads on the U-bolts are rolled, using a die will not work and is dangerous (they will get stripped most likely) - i suggest rather using a spacer.
you can get rid of the sway bar, i drove the Jeep like that for years with no ill effects that i noticed, if you really want to keep it i suggest a grade 8 bolt long enough to go across the bottom plate
« Reply #2 on: April 03, 2011, 03:18:49 PM »
I am sure there is a place around there somewhere that makes leafsprings they can make you the correct U bolts. Spacers will work, but u bolts of the correct length is the best way to go. For the sway bar you could do as you proposed provided that the links do no invert when fully flexed out. You could also weld tabs on the axle tubes, to keep the links closer to stock length
« Reply #3 on: April 03, 2011, 08:56:13 PM »
I would have to see if I can find those square shaped ones locally; or call dynatrac and complain, but that may take a while...  You really think they would strip if I use a die?
I am actually thinking about just ditching the swaybar, but I do make that one long drive every 3 months...  I am just worried about how the Jeep would handle if I have to do some emergency manouvering at highway speeds (not having a swaybar can make rolling over easier, I think).
« Reply #4 on: April 03, 2011, 10:15:40 PM »
put a caliper on it, the bolt is a tiny bit smaller than the threads i think, i'll measure one in the garage later and let you know what i find. I am pretty sure you won't be able to use the same torque as the on rolled thread.
mine handled just fine and was quite good on corners, i was surprised how little if any sway developed after taking it off. My springs were stiff though but so are most of the lift kits, stock leafs are a different story.
« Reply #5 on: April 04, 2011, 12:12:28 AM »
I tried no swaybar on the YJ, found that under emergency braking, it can be a handfull, I drive LONG trips in mine and I would not permanently remove it..
Noteably down hill on a turn is flat scary if I have to brake. Now th etrack bars are dead weight, they got stripped off about 2 months after I bought it...
« Reply #6 on: April 04, 2011, 12:17:41 AM »
I measured one, the round is 0.75mm smaller in diameter than the threaded portion - so unless the ones you have are different it's def not a good idea to use a die to extend the thread (this is on top of the fact that a cut thread would be weaker to begin with).
« Reply #7 on: April 04, 2011, 12:29:46 AM »
+1 on that, rolled threads only on U-bolts. the Nuts are special too BTW, they are a longer nut with a staked end to make them stay on.. They will cut the threads up if the threads are cut instead of rolled.
I'd bug Dynatrac they are a good outfit fomr my limited dealings with them...
« Reply #8 on: April 04, 2011, 07:51:37 AM »
If you want to be able to take the u-bolts off and then put them back on (broken centering pin trail fix), I recommend cutting the u-bolts with a hacksaw. It will be a pain but the threads will be good at the cut ends.  The angle grinder, on the other hand, will deform them to the point that they will not work.  Or you could try putting your thread die on there, then cut the bolts and then recut the threads as you take the die back out.
« Reply #9 on: April 04, 2011, 08:34:23 AM »
For the sway bar.  This might work:  Put some angle iron over the top plate, it will be held on with the u-bolts.  Then weld a bolt onto the part that hangs down in front of the axle.  It will end up above the springs so you might still need to cut the links a bit.  You might want to use material thicker than 1/4 (just guessing).
« Reply #10 on: April 04, 2011, 08:35:04 PM »
Well, I just sent Dynatrac an e-mail...  Let's see what they say.
« Reply #11 on: April 04, 2011, 09:06:46 PM »
did you measure the threads and round? just wondering if they are the same (thread larger diameter) as the ones i have.
« Reply #12 on: April 04, 2011, 09:26:27 PM »
I just trimmed mine. As long as you leave the nut on before you cut it you should not have a problem. When you remove the nut it takes care of the burr.
I don't run a sway bar so the swap was pretty easy.
Also I needed to grind the corner of the plate a fair amount so the shock body would not be dented. Be sure to check your clearance.
« Reply #13 on: April 05, 2011, 07:40:48 AM »
I once took the nuts off of some cut u-bolts and they would not go back on.  It was late at night, too late too buy new ones, so I ended up tapping them, which allowed them to go back on until I could get some new ones.  So at the very least it would be good to pack some extra nuts.
« Reply #14 on: April 05, 2011, 08:24:39 AM »
There is that risk. I put lots of lube (anti-seize) on there. Also ran the nut back and forth a number of times before removing it.
