Author Topic: Dynatrac High-Clearance U-Bolt Kits and sway bars...  (Read 4900 times)
Re: Dynatrac High-Clearance U-Bolt Kits and sway bars...
« Reply #15 on: April 05, 2011, 08:29:17 AM »
I just trimmed mine. As long as you leave the nut on before you cut it you should not have a problem. When you remove the nut it takes care of the burr.
I did that for the rear; again, those are on, but I had to use one bolt from the front kit because the thread was not long enough.  I left the bolts a bit long so that I can ise them to bolt on a bump stop extenion on top of the rear axle so that the rear suspension does not hit the body like it has in the past at max flex.
Also I needed to grind the corner of the plate a fair amount so the shock body would not be dented. Be sure to check your clearance.
Where did you have problems?  Front or rear?
did you measure the threads and round? just wondering if they are the same (thread larger diameter) as the ones i have.
No; I am currently in Panama, and the Jeep is in Costa Rica...
« Reply #16 on: April 05, 2011, 11:39:17 AM »
It's best to cut the bolts with the nuts on so you can chase the threads by taking the nut off.
« Reply #17 on: April 05, 2011, 02:12:34 PM »
On the fronts. Not sure if I have a PIC or not.
« Reply #18 on: April 06, 2011, 08:07:11 AM »
I did that; no worries with the cutting part...
Also, Dynatrac responded; it seems they will be able to help...
Quote from: dynatrac
What size of square u-bolt do you need?  are you saying that two of the u-bolts were different size than the others?
supply me the lengths you need so theres no further mistakes.
You can use a set of shock mounts for the sway bar mount on the front axle
I may not be able to cover all of the shipping charges.
Thank you,
Steve Marrone
National Sales Manager
Dynatrac Products, Inc.
(714) 596-4461 X201
Of course, i am still on business trip, so I will need to wait till I get back to respond to them...
« Reply #19 on: April 07, 2011, 01:29:27 PM »
Well, they are sending me new U-Bolts via UPS all the way to Costa Rica...  Not bad service AT ALL!!!
