Author Topic: Flat tow w 8.8 Limited slip?  (Read 2029 times)
AGUHR
« on: April 07, 2011, 05:41:32 PM »
Can you flat tow a jeep with a limited slip in the rear axle or will it simply eat the crap out of the tires? should I consider putting a selectable locker in?
I'm putting an 8.8 in, I was considering limited slip but I want to make sure I can still flat tow it.
Re: Flat tow w 8.8 Limited slip?
« Reply #1 on: April 07, 2011, 06:10:20 PM »
There shouldn't be any more wear then if you drive it.
AGUHR
« Reply #2 on: April 07, 2011, 06:27:44 PM »
common sense should have ruled in my mind before i posted this - thanks Jeffy
thats one of those - "heres your sign" moments.
« Reply #3 on: April 08, 2011, 11:44:39 AM »
I flat-tow with spools in both axles, no problems.
