Author Topic: ARB Announces New Compressor.  (Read 1522 times)
« on: April 11, 2011, 01:43:30 PM »
PRODUCT RELEASE
CKMTA12 / 24
Copyright © 2011 by ARB Corporation Limited
ARB 4x4 ACCESSORIES
720 SW 34Th Street Renton, Washington 98057 USA
North and South American enquiries
Tel:   (425) 264-1391 Fax: (425) 264-1392
sales@arbusa.com
www.arbusa.com
ARB Air Compressors
ARB CKMTA12 / 24
MAXIMUM PERFORMANCE ON-BOARD AIR SUPPLY
Brief Description:
ARB's new CKMTA12 and CKMTA24 twin on-board compressor kits were designed to fill the market need for a compact sized yet high-volume compressed air source to suit the high volume airflow needs of most air powered tools, and also to suit the actuation and control needs of the ARB Air Locker, and the harsh and demanding environment of the ARB Air Locker user.
Features:
␣   Available in 12V (CKMTA12) or 24V (CKMTA24) models.
␣Constructed primarily of light weight, high strength, engineering grade materials, including military and aerospace standard components.
␣   Pressure switch controlled air manifold system regulates pressure between 9.3Bar [135PSI] and 10.3Bar [150PSI] suited to air tools and all ARB Air Locker equipped vehicles.
␣   Highest air flow rate of any 12V compressor of its size on the market at 174LPM [6.16CFM].
␣   High efficiency design consumes only 56 Amps at maximum air flow.
ARB Air Compressors
␣   Built with sealed components for moisture and dust resistance. ␣   Hard-anodized cylinder bores and PTFE (Teflon) impregnated carbon
fiber piston seals for reduced friction and maximum trouble free life.
␣   Ducted IP55 sealed brushless DC cooling fan and anodized motor mounting brackets effectively dissipate heat from the motors, heads and electronics allowing for a 100% duty cycle (under room temperature conditions).
␣   Anti-vibration / sound deadening is integrated into the mount. ␣   Relocatable splash resistant air filter assemblies for cleaner, cooler air
supply and versatile waterproof air intake positioning.
␣   High density and high flow washable sintered bronze air filter elements.
␣   Full wiring loom included for simplified installation and easy plug-in connectivity to Air Locker control solenoids. (Note: Air Locker Manifold Kit #171503 required to mount solenoids)
␣   Equipped with dual heavy duty Maxi-Fuses for professional in-line circuit protection and true circuit redundancy in case of a fault.
␣   Motors are water sealed, 100% ball bearing equipped (i.e., no bushings used), and feature a unique linear brush pre-load system for extra long life, low heat and quiet operation throughout the life of the unit.
␣   Motors are internally thermal protected against extreme temperature damage.
␣   Compressor pistons are equipped with a heavy duty European made cylindrical roller bearing.
␣   Over-pressure safety valve equipped. ␣   Sealed illuminated automotive grade dash switch included. ␣   Fully serviceable and all replacement parts available. ␣   EMF suppressed for use in proximity to sensitive electronic equipment. ␣   CE and C-Tick compliant.
␣   Engineered, built, and individually dyno-tested in Australia from local and imported components.
ARB Air Compressors
Applications:
␣   Pneumatic supply and electrical control for ARB Air Locker(s). (Air Locker Manifold Kit #171503 required)
␣   Rapid inflation of small, medium and large tyres. ␣   Air tools rated up to 85LPM [3CFM] @ 6Bar [90PSI] continuous supply. ␣   Air tools rated higher than 85LPM [3CFM] @ 6Bar [90PSI] using an
optional air tank suitable to the run time requirements.
Notes:
␣   All ARB CKx series compressors share a unified wiring loom from the switches to the 4 terminal junction and therefore this section of the loom does not need to be replaced if upgrading an existing CKx series compressor.
␣   A manifold kit (#171503) is recommended for Air Locker solenoid mounting with CKMTx compressors.
ARB Air Compressors
Kit Includes:
␣   Fully assembled and tested air compressor (12V or 24V). ␣   Complete wiring loom w/ Air Locker solenoid plug-in terminals. ␣   Automotive OEM quality compressor isolating switch. ␣   2 x relocatable splash resistant air filters with washable high-flow
sintered bronze filter cartridges. ␣   Mounting bolts and washers. ␣   Comprehensive photo illustrated installation guide.
CKMTA12 KIT CONTENTS SHOWN
ARB Air Compressors
TECHNICAL SPECIFICATIONS
ARB
AIR COMPRESSOR RANGE
MODEL NUMBER   DESCRIPTION
CKSA12 COMPACT ON-BOARD 12
PERFORMANCE UNDER NO LOAD
AIR FLOW
PERFORMANCE UNDER LOAD
AIR FLOW
WEIGHT -compressor & included accessories
SIZE mm [inches] -when positioned vertically
in the mounting bracket. -portable compressor sizes shown as carry case size.
HEIGHT LENGTH WIDTH
@ 0Bar
5A 25.0LPM 13A 75.1LPM
@ 0PSI
0.88CFM 2.65CFM --- 2.65CFM 6.16CFM 6.16CFM 6.16CFM
@ 2Bar
6.5A 13.4LPM 22.9A 61.6LPM
@ 29PSI
0.47CFM 2.18CFM --- 2.18CFM 4.65CFM 4.65CFM 4.65CFM
Kgs
Lbs
CKMA12 CKMA24 CKMP12
HIGH VOL ON-BOARD   12 HIGH VOL ON-BOARD   24 HIGH VOL PORTABLE   12
--- 13A 75.1LPM 28A 174.3LPM
--- 174.3LPM 28A 174.3LPM
--- 22.9A 61.6LPM
50A 131.7LPM --- 131.7LPM 50A 131.7LPM
2.4 5.3 4.5   9.9 4.5   9.9 6.6   14.5
35% 21/39 50% 30/30 50% 30/30 50% 30/30
122mm [4.8"] 142mm [5.6"] 142mm [5.6"] 208mm [8.2"] 102mm [4.0"] 102mm [4.0"] 190mm [7.5"]
162mm [6.4"] 190mm [7.5"] 190mm [7.5"] 440mm [17.3"] 190mm [7.5"] 190mm [7.5"] 480mm [18.9"]
88mm [3.5"] 96mm [3.8"] 96mm [3.8"] 238mm [9.4"] 275mm [10.8"] 275mm [10.8"] 340mm [13.4"]
CKMTA12 MAX VOL ON-BOARD 12
CKMTA24   MAX VOL ON-BOARD   24 CKMTP12* MAX VOL PORTABLE 12
19.4 100%
19.4   100% --- --- 100%
8.8 8.8
1
* available mid 2011 1 requires optional manifold kit #171503 -All ARB Air Compressors are individually leak tested, pressure tested, current draw tested and flow tested
under load at the factory before packaging. -ARB Air Compressor pressure switches are specially designed to suit the working pressure range of an
ARB Air Locker air operated locking differential. -All specifications here are average nominal values recorded during factory testing, and these values may
1
vary as materials technology and component design undergoes continuous improvement.
SUPPLY VOLTAGE CURRENT DRAW
CURRENT DRAW
DUTY CYCLE % @ 22°C [72°F] (on time / off time)
AUTOMOTIVE CURRENT LOAD PROTECTION IN LOOM AIR LOCKER SOLENOID MOUNTING MANIFOLD
PRESSURE CUTOUT SWITCH
DURABLE POLYPROPYLENE CARRY CASE
AIR FILTER EQUIPPED
6 METER [20 FT] TYRE INFLATION HOSE
THERMAL OVER-LOAD PROTECTED MOTOR
PERFORMANCE BY COMPRESSOR SERIES
CKMT Series
CKM Series
CKS Series
http://www.arbusa.com/uploads/PDF/newProductAdvice/CKMTA12_retail.pdf
Re: ARB Announces New Compressor.
« Reply #1 on: April 11, 2011, 08:57:37 PM »
I just wonder where one would mount it; it seems a bit wide...
