Author Topic: What do you think of this performance ignition kit?  (Read 2223 times)
Offline andpgud
« on: April 18, 2011, 04:46:27 AM »
Have you had eny experiance with it? Is it worth it? Do you recommend something else and I am about to change my spark plugs, What should I go with on my 4 banger?
http://www.quadratec.com/products/17610_61X_PG.htm
Re: What do you think of this performance ignition kit?
« Reply #1 on: April 18, 2011, 10:38:54 AM »
Many of us here run the Performance Distributor Ignistion; but keep in mind that the one you listed is for the 6 cylinder, not the 4.  If you want the 4 cylinder kit (which includes the aluminum wire holders), you have to go to their web site...  In my case, other than one fried screaming demon coil (which I replaced with another SD), I have had pretty good results.  By the way, the coil most likely died from being submerged so many times...
« Reply #2 on: April 18, 2011, 04:56:14 PM »
Actually it's just the picture that is wrong.  The description is right.
« Reply #3 on: April 18, 2011, 09:06:51 PM »
I ordered mine straight from PD. They are great to deal with. IIRC the plugs they recommend are Autolite. I forget which ones.
« Reply #4 on: April 18, 2011, 11:52:47 PM »
Platinum's.
