Author Topic: wierd radiator leak  (Read 4643 times)
gomi
wierd radiator leak
« on: February 28, 2006, 03:42:41 PM »
Hello guys. I've got this strange radiator leak. It has only happened twice now and on both occasions the weather has been below 10 degrees farenheit. It seems to be leaking along the top seem of the radiator and along the edges both where the radiator meets up with the fan shroud. It isn't a huge leak, doesn't even drip onto the floor. It just kind of seeps out of somewhere.  Could it be a hose of somesort? a mechanic who goes to my gym said it could be because of the metal expanding and contracting due to the cold, but I have no idea. There was a bit more coolant visible around the top near the hose, but the hose itself was rather dry. Thanks for any help anyone can give me.
wierd radiator leak
« Reply #1 on: February 28, 2006, 07:47:59 PM »
Seems logical.  The top of the tank is plastic that is clipped onto the metal tank.  They are known to seep and leak.
Gearhead2.5
wierd radiator leak
« Reply #2 on: February 28, 2006, 08:12:44 PM »
Could be a bad solder joint where the filler neck is attached to the top tank. I bought a new rad last year , it leaked from the first day at that spot , it was warrantied and replaced.
Could be a bad cap too.
Have some one pressure test the cooling system and the cap at the same time to find the leak.
gomi
wierd radiator leak
« Reply #3 on: February 28, 2006, 08:20:51 PM »
Quote from: "Jeffy"
does this mean I need to replace the radiator?
Erik
wierd radiator leak
« Reply #4 on: February 28, 2006, 09:27:31 PM »
Yes... unless you can fix it... but a replacement would be easy and quick
gomi
wierd radiator leak
« Reply #5 on: March 01, 2006, 12:13:41 PM »
WOW!! I took it to the jeep dealership and it's gonna cost $$565. I can't do it myself so :cry:
lanulos89
wierd radiator leak
« Reply #6 on: March 01, 2006, 12:50:06 PM »
to replace the radiator?  Take it to a regular shop it will probably be cheaper.
wierd radiator leak
« Reply #7 on: March 01, 2006, 01:06:53 PM »
Why can't you you do it yourself?  It's not that hard and a replacement is around $200.
If it's not seeping much then I'd just leave it.  10* below is pretty cold and because the tanks are plastic it will not shrink or expand as much as the metal.  If it's doesn't have a problem at warmer tems then I'd just leave it and watch it for a while.
jt04GT
wierd radiator leak
« Reply #8 on: March 03, 2006, 09:46:18 PM »
I had a similar problem, 116K on the original, just steamed a litte every now and then, more noticeable on cold humid days below 30.  Even with the leak, never runs hot or overheats.  When cold, there's no leak, even with a pressure test at a service station.  This went on for months.  The plastic metal ones do this when they get old.  The mechanic said to leave it and wait until warm weather, but I had some extra cash and decided to replace it with a new all metal one.  It cost under $200 for the radiator alone but since was too cold out, I paid to have it installed: $370 total job at a local service station, no more leak and piece of mind for the summer when it hits 98 out!  Plus the aftermarket on is all black, looks cool through the grill!
wierd radiator leak
« Reply #9 on: March 04, 2006, 05:38:42 AM »
Replace it yourself, it's easy with handtools.  www.radiatorbarn.com for a great price on an all-metal replacement radiator.  They have quick shipping and a warranty, I know a lot of people that have been happy with them.
TJJim
wierd radiator leak
« Reply #10 on: March 04, 2006, 08:45:45 AM »
Kind of on the same topic.
Has anyone concidered using the transmission oil cooler as a haet exchanger for an on-board shower?
Jim
wierd radiator leak
« Reply #11 on: March 04, 2006, 12:31:35 PM »
Quote from: "TJJim"
Jim
Nope, but a friend of mine used to make heat exchangers that tapped into the heater.  The advantage was that you can control the temp though the heater, I believe.
TJJim
wierd radiator leak
« Reply #12 on: March 04, 2006, 07:40:12 PM »
I was thinking about either using  either a mixing set- up or possibly flow rate of the pump.  Higher flow-rate = lower temp.
Jim
