Author Topic: fuel cell in my jeep???  (Read 2407 times)
95yjzilla
« on: April 30, 2011, 04:17:43 PM »
im thinking bout putting a fuel cell in the back on my jeep instead of just making a access door to the fuel pump. wat do  are ur guys ideas bout doing tht? need to know how much its goin to cost also and to purchase one
thanks, matt
Re: fuel cell in my jeep???
« Reply #1 on: April 30, 2011, 05:37:39 PM »
Most I know use the RCI universal - http://www.summitracing.com/search/?keyword=RCI-2161A%20&dds=1  Then use the stock sender or if you don't care about having a gauge or else want to swap out the stock gauge then there is a sender in the tank IIRC.
There is also a 19 gallon cell that would also fit if you didn't want a rear seat and wanted more range.
95yjzilla
« Reply #2 on: April 30, 2011, 05:43:36 PM »
yea i was goin to use the RCI universal one. i would use the stock sender if theres one that comes with the fuel cell. im goin to use the stock gauge in my jeep because its my daily driver and off road jeep. my rear seat is already out of my jeep. ill probly just got with the 15 or 16 gallon tank
« Reply #3 on: April 30, 2011, 05:51:18 PM »
You can't use the sender that's in there for the gauge.  They are incompatible from what I've heard.  I haven't checked it but IIRC, the Jeeps sender is reverse.  So it would probably be best to just reuse your sender and pump.
« Last Edit: April 30, 2011, 05:55:54 PM by Jeffy »
95yjzilla
« Reply #4 on: April 30, 2011, 06:00:10 PM »
this is pretty much wat i wanna do with my fuel cell that i want to install in my jeep
http://www.4wdandsportutility.com/features/jeep/1002_4wd_1991_jeep_wrangler_yj/photo_09.html
95yjzilla
« Reply #6 on: April 30, 2011, 06:19:09 PM »
i deff wanna do tht. i hate dropping my tank. was goin to cut a square in my tub just over the fuel pump and replace the fuel pump that way then seal it back up
« Reply #7 on: April 30, 2011, 07:03:41 PM »
before you do all this work, are you sure it's the fuel pump? did you do a fuel pressure test while driving to monitor it when you say your Jeep is bogging down? Not saying it's a no-no or a bad idea but you might end up doing all this work for the wrong reason.
95yjzilla
« Reply #8 on: April 30, 2011, 07:29:35 PM »
no i havent. i cant do over 20 mph on the road and i dont have the tool to do it with. its gotta be the fuel pump bc ive pretty much have changed everything else in my jeep to make it stop spuddering and spitting
« Reply #9 on: May 02, 2011, 08:47:07 PM »
To be honest, dropping the tank will be A LOT less work than cutting the tub...  All you have to do is release the fuel filler hoses, loose 7 nuts, and bring the tank down with a hydraulic jack.  It's really not rocket science.  I have dropped mine at least 4 times, with a 4th one coming up sometime soon (I would say next weekend, but since I leave tomorrow on a business trip until Saturday, my wife probably has something to say about that!).  Takes about an hour to drop it and put it back on (plus whatever time you take to work on whatever you are working on).
« Reply #10 on: May 03, 2011, 08:19:20 AM »
X2 on dropping the tank. had to drop mine last summer after it got in a fight with a rock and it came out and went back in far easier than expected.
Offline aparke4
« Reply #11 on: May 11, 2011, 01:32:40 PM »
If going fuel cell route kore makes a ring that adapts stock pump to cell. This way you keep gas gauge and wiring. And is a cheaper route than electric external which requires more smaller fittings and braided hose etc.
