Author Topic: Motice Products Bleeder  (Read 2071 times)
« on: May 05, 2011, 07:54:09 PM »
  Will Highly recommend this.  Just got new front brake lines so I needed to bleed the brakes when I was done.  So Ordered the Domestic car kit.   I had used what we called a bleeder ball while in the military so was used to using something like this..
   What would have taken a lot of pumping the Petal took less than 10 minutes and that included time to put the bleeder together and mounted to the Master Cycl.  Got a nice solid brake petal.
Re: Motice Products Bleeder
« Reply #1 on: May 05, 2011, 09:30:04 PM »
Title should say Motive Products Bleeder.  And its Pedal not petal.  Why is there not edit available for posts.
« Reply #2 on: May 05, 2011, 10:36:04 PM »
there is but not beyond a grace period, so right after for about 15 min you should be able to modify your post, not past that time (or whatever the time is, just guessing the 15 min).
Offline aparke4
« Reply #3 on: May 11, 2011, 01:42:04 PM »
How much did it run ya?
« Reply #4 on: May 11, 2011, 02:46:11 PM »
Pressure bleeders are nice, however a bottle with some brake fluid in it and a hose that extends into the fluid and has the other end attached to the bleeder screw at the wheel works well for one man bleeding. That or a hypodermic needle with a piece of hose on it, works like charm and either one will cost next to nothing.
« Reply #5 on: May 11, 2011, 05:38:19 PM »
I use a mighty-vac.
