Author Topic: Hammerite  (Read 2416 times)
jackhammer
Hammerite
« on: March 04, 2006, 09:12:26 AM »
Last night I went to my uncles house. He has a heated garage with compressor.  I used a couple different sized scrapers, wire brush, and wire brush bits on a drill. I pulled the front bumper and plastic cover that says Jeep on it that sits parelel to the ground.  I sraped and brushed and drilled my frame from front to back at every angle I could get at. I then used the compressor to blow off dust and such.  Then washed with soapy water.  I did one thick coat of rustoleum rust reformer(goes on white turns black as dries.) I then sprayed 2 coats of black hammerite rustoleum.  I really like how the hammerite texture looks on the frame. Tends to hide the runs and drips as well as uneven surfaces from scraped paint bubles and such.  My question is this.  My uncle cant hold his booze and got all wierd buy the time I was applying the hammerite. So I had to get out of there before I had to smack him(thats happened a few times before) Since it was like 27degrees outside do you think that will cause the paint to peel and such.
Hammerite
« Reply #1 on: March 04, 2006, 12:21:32 PM »
Was it Hammerite brand or Rustolium 'Hammered' finish?  There is a difference.  Hammerite has crushed up glass which give it a hard finish.  Rustolium doesn't.  You might be ok if you applied the coats lightly and built them up.  500w shop lights would help to dry it.  You might be ok if the rust reformer went black and dried before you started spraying.  How thick were your coats?
jackhammer
Hammerite
« Reply #2 on: March 04, 2006, 01:03:04 PM »
Rustoleum hammered finish.  I did wait untill Reformer turned black. I plan to leave it till september.  Whatever bubles or flakes I will POR15 in sept.  I will check condition in early november again right before I have a ziebart undercoating done before the salt hits the streets in chicago.  I new I wasnt using the best paint but I figured doing something was better then nothing(dont you agree when it comes to rust). I only spent about $25 on this.
