Author Topic: what clutch are you running with  (Read 4205 times)
WranglerCOdy
« on: December 22, 2011, 10:48:27 PM »
i need a new clutch agian and im not putting a new advance auto parts in it. im looinig for a little bitof a better clutch that i can more than a year.
Re: what clutch are you running with
« Reply #1 on: December 23, 2011, 09:58:36 AM »
Mine is still the stock one. I'd go with another one. Or one made by Luk. Nothing real aggressive.
« Reply #2 on: December 23, 2011, 10:35:52 AM »
160,000 and still on the stock one.
« Reply #3 on: December 23, 2011, 12:13:07 PM »
something with slipping the clutch probably cause the 1 year failure - could be some oil coming out of the input shaft seal on the transmission or maybe you burned it on some offroad runs, should last way longer than 1 year.
« Reply #4 on: December 23, 2011, 02:19:20 PM »
Maybe the Florida mud and crud keeps getting in there?
« Reply #5 on: December 23, 2011, 02:55:39 PM »
I'm on my stock as well.  LUK is good.  I don't see any reason to get a Centerforce.
WranglerCOdy
« Reply #6 on: December 23, 2011, 09:55:21 PM »
my last clutch had a broken spring and i thing this one has a bad throw out bearing. and just wont really hold
« Reply #7 on: December 24, 2011, 07:47:56 AM »
Go with a stock replacement LUK brand clutch.
  • 4BangerJP.com® Donator
« Reply #8 on: December 24, 2011, 09:10:40 AM »
Mine probably has the oem '94 clutch that it came from the factory with.  There's some slippage, but that's been that way since '99 when I bought the jeep (actually I'm pretty sure I'm the one who caused the slippage in the first place ..Don't ask what I was doing to the thing on the solo test drive...).
I guess you do a replacement Luk or whatever, you'd want to resurface the flywheel, right?  And can't use the "weights" on the Centerforce upgrade, I guess.
« Reply #9 on: December 25, 2011, 10:57:25 AM »
I now have stock exedy replacement clutch had to some zoom performance one stay away it was crap and large waist of money... Luk is also a really good quality clutch!.
WranglerCOdy
« Reply #10 on: December 26, 2011, 08:37:31 AM »
you have the part number for that exedy
« Reply #11 on: December 26, 2011, 08:50:42 AM »
I can get it later I'm out of town visiting family right now :D and it's a stock replacement one.
« Reply #12 on: December 26, 2011, 09:00:41 AM »
What did you not like about that clutch?
« Reply #13 on: December 26, 2011, 09:38:38 AM »
I like my exedy one.
the ZOOM PERFORMANCE  one is junk didn't last 3 months started slipping. was suppose to be some great performance one and didn't even make break in period
« Reply #14 on: December 26, 2011, 09:39:20 AM »
