Author Topic: CAD  (Read 5627 times)
Offline 95 Lowbuck
CAD
« on: February 04, 2012, 07:00:52 PM »
So my CAD quit working and I decided to just get
a TJ axle and the Napa seal and be done it.
At teardown of the CAD motor I noticed water coming
out of the ports.
So I cycled the diaphram upside down by hand a few times
to get all the water out and it started working again.
Would look there first if any CAD problems.
Still doing the axle swap, got all the parts.
Re: CAD
« Reply #1 on: February 04, 2012, 07:03:48 PM »
what's CAD?
Offline 95 Lowbuck
Re: CAD
« Reply #2 on: February 04, 2012, 07:21:55 PM »
Central Axle Disconnect
Re: CAD
« Reply #3 on: February 06, 2012, 12:22:23 PM »
i heard of it being called Quick Axle Disconnect or passenger axle disconnect, didn't know it's also called CAD or Central - good to know.
Re: CAD
« Reply #4 on: February 06, 2012, 05:08:09 PM »
I just put in a posi lok cable system. ditch the vacuum lines and switches
http://www.4x4posi-lok.com/app_jeep.html
« Last Edit: February 06, 2012, 05:11:07 PM by Torch_Ind »
Re: CAD
« Reply #5 on: February 06, 2012, 05:16:21 PM »
i've heard guys running this with a spool up front and use this posi lock instead of a selectable locker, is that what you did or just wanted to get rid of the vac motor?
Re: CAD
« Reply #6 on: February 06, 2012, 06:17:17 PM »
I only got rid of the vacuum
Re: CAD
« Reply #7 on: February 06, 2012, 06:38:24 PM »
I've also heard of some people doing that but it's a weak point.  Better to with a locker and swap out the shafts for TJ stuff.  Most YJ's are going to have the 260x instead of the 297x U-joints anyway.
Re: CAD
« Reply #8 on: February 07, 2012, 03:53:33 AM »
Or simply install the disconnect upside down to hold the shift collar in the locked position and you save money and time.
I ran a front spool with my CAD for years, no problems. Had a manual vacuum switch on the d30 and now a cable to control the disco 44.  Poor-man's selectable  :smokes:
Re: CAD
« Reply #9 on: February 07, 2012, 04:56:58 PM »
 :thumb: good to know. I do highway with my yj and it vibrates cause I don't have double cardigan joints on my front shaft for the angle I am running but the cable works good for me.
with the spool does it spin the front shaft when the disconnect is disengaged?
Re: CAD
« Reply #10 on: February 07, 2012, 05:06:36 PM »
yes, it would spin the front shaft
i don't think the problem is that you don't have a CV joint (you shouldn't need one in front unless you run some ridiculous amount of lift since the d/s is quite long), the issue as far as i know is that the YJ front d/s is not balanced, that would fix your vibration. not that a CV would hurt but i don't think you don't need it.
« Last Edit: February 07, 2012, 05:15:55 PM by sharpxmen »
Offline 95 Lowbuck
Re: CAD
« Reply #11 on: February 07, 2012, 05:09:08 PM »
Yes
Re: CAD
« Reply #12 on: February 07, 2012, 05:11:26 PM »
X2, it is most likely that your front DS needs to be balanced, or worst case is slightly bent.  I'm currently running the front with a single cardan DS and the front axle connected with no noticeable vibrations.
Re: CAD
« Reply #13 on: February 07, 2012, 06:24:55 PM »
This is correct.  The front driveshafts weren't balanced since they weren't designed to spin all the time.  4WD is supposed to be limited to 55MPH and only spins the shaft when in 4wd.  Add a locker or a LSD and the front shaft spins 24/7.  This can also cause pinion seals to leak if the shaft hasn't turned in a while.
So any vibrations are probably from an inbalanced driveshaft or poor U-joint angles.
« Last Edit: February 07, 2012, 06:25:29 PM by Jeffy »
Re: CAD
« Reply #14 on: February 07, 2012, 07:53:43 PM »
I'm guessing mine is a bit of both it shakes before 55mph for me. but my angle isn't the best with my lift.  I was thinking about finding a TJ front drive shaft with the double cardan joint
