Author Topic: Yet MORE coil problems...  (Read 23778 times)
Re: Yet MORE coil problems...
« Reply #45 on: April 01, 2012, 04:27:24 PM »
i wonder if this is why your PCM got fried a while back (if it did, i seem to recall you said something to that nature in one of your threads).
No, that was a friend, not me.  I did buy a used ecu when that happened to him to keep as a spare, but mine is still alive and kicking.
« Reply #47 on: April 01, 2012, 05:49:35 PM »
Glad I could help.
« Reply #48 on: May 06, 2012, 10:16:31 PM »
So, I put in a new Mopar coil, the new connector, checked everything, and they coil started acting up again (I swaped it out before I burned it).  Do I now install the Mallory 0.7-1.5 Ohm ballast resistor?  I am also considering installing a new mounting bracket to the frame to get the coil  away from the enginr's heat (in case that's what's causing the problem...  Any other ideas are welcome!
« Reply #49 on: May 06, 2012, 11:04:01 PM »
swap the PCM and see if it does it again (you have a spare right?)
« Reply #50 on: May 06, 2012, 11:40:07 PM »
I did that when I put in the coil that started acting up...
« Reply #51 on: May 06, 2012, 11:43:12 PM »
i've never seen this happening before with all the things you swapped already so i'm out of ideas.
« Reply #52 on: May 06, 2012, 11:49:49 PM »
I think I will install the extra coil bracket (it would make cvhanging coils on my way to Panama) and include the. Ballast resistor there.  I will order a coil extension chord, and have it ready to plug into the resistor if that coil fails.  I just need to figure out how to make the holes the the frame, as I just found out my drill will not fit in there...
« Reply #53 on: May 07, 2012, 09:24:00 AM »
Ok just read everything again and did not see this.  Have you changed the coil Wire.  Had one on my truck(One coil per Cylinder) and started frying coils.  It ended up being the coil wire had a internal break.  This would act just like you had a too large of plug gap and overheat the coil.
  Just a shot in the dark.
« Reply #54 on: May 07, 2012, 08:48:56 PM »
At this point, its worth a try, but I doubt this is the issue, as it has dones for a while now.  How about a bad grou d?  Vould that be the cause?  How would I check for this?
« Reply #55 on: May 07, 2012, 08:57:01 PM »
Pull the wire check for resistance.  While doing it move the wire around.  Mine showed a a break.
« Reply #56 on: May 08, 2012, 09:02:29 PM »
Anyone knows where I can get an extension of the coil wire?  I want to modify one to use with the ballast resistor (so it will be easy to plug it in or bypass it), but I cannot find one online...
« Reply #57 on: May 08, 2012, 11:07:06 PM »
If you have not changed the Distributor and are using a stock coil, there is something else wrong.
« Reply #58 on: May 09, 2012, 03:13:32 PM »
I still think there is an issue with the stock wiring.  There's too much resistance in that wire which is causing it to overheat and melt the plug/coil.
« Reply #59 on: May 09, 2012, 03:25:11 PM »
Wonder if somehere before the wires were reversed to the coil.
Here is a way to check.
http://mgaguru.com/mgtech/ignition/ig104.htm
