Author Topic: Busted Motor Mount Bolts  (Read 5251 times)
« on: April 04, 2012, 09:59:54 AM »
Driver side motor mount bolts all sheared off in the block last night. At least it happend in the Home Depot parking lot and I went inside and got some metric M10-1.5x30mm bolts needed. I'm limping on one bolt until I can pickup a buddy's right angle drill and extract the other two tonight. Did some research and looks like this is a common deal.  I just order a Brown Dog motor mount kit which uses 6-7 bolt into the motor rather than only 3 the oem bracket uses - it'll be here within 10 days.  I'll snap some pics and post them soon. BTW, Karol at Brown Dog is awesome.
http://browndogindustries.com/S2883-1-Jeep-I6-Super-Engine-Mounting-Kit-1-Inch-Motor-Lift.aspx
« Last Edit: April 04, 2012, 10:01:17 AM by 1995yj »
cman
Re: Busted Motor Mount Bolts
« Reply #1 on: April 04, 2012, 12:02:07 PM »
Thats for a 4.0l not a 2.5l it will not fit
« Reply #2 on: April 04, 2012, 12:14:34 PM »
I've got a '03 Rubicon now - but I still enjoy this forum though.  ;)
« Reply #3 on: April 04, 2012, 01:15:25 PM »
$314 vs $15?
I hate poly mounts.  They transmit too much vibrations to the body.  If it's a daily driver then I'd pass.  Honestly, I'd just replace the mount and be done with it.
« Reply #4 on: April 04, 2012, 03:09:37 PM »
I'm already running the bomb proof more engine mounts. The 3 bolt bracket that attaches to the block is what broke free - the engine side bolts snapped. Brown Dog actually is giving me a discount if I send them the old mounts. I'm basically getting the engine mounts for free. What I really need is the bigger bracket. I also spoke with them, and there's a rubber upgrade kit incase the poly is too rough/loud.
http://browndogindustries.com/search.aspx?find=rubber&page=4
The oem holes is what busted on mine - two upper holes still have broken bolts in them. The other holes should be were the new brackets attach.
« Reply #5 on: April 04, 2012, 05:27:10 PM »
Then it sounds like a good deal then.
« Reply #6 on: April 04, 2012, 08:46:31 PM »
$250 for the Brown Dog brackets and trade in on the engine mounts
$28 for a drill at HF since no one I know close by has one
$5 in bolts (to fix it for now)
$50 for a 16" Perma-Cool 2950CFM electric radiator fan off CL and $43 for a Derale contorller from Amazon (broke the shrowd when the motor flopped - good reason to upgrade)
$50 on a Cobra CB 29 NW LTD with antenna off CL
$60 in front lower and upper arm bushings - the knocking been driving me nucking futs.
Its another Just Empty Every Pocket month. ;) Glad I got 21 hours of OT.
The bolts only needed a light coaxing to get them to come loose. The punch to set the drill bit starting point and the WD-40 I sprayed to save my drill bit really loosened it more than anything. Now, as long as I keep it on four wheels I'll be ok until the brackets come.
« Last Edit: April 04, 2012, 08:52:19 PM by 1995yj »
« Reply #7 on: April 04, 2012, 08:52:39 PM »
Honestly, I'd probably just fix it be done.  Also, if you used a reverse cut drill bit it probably would have unscrewed on it's own.
« Reply #8 on: April 04, 2012, 08:58:48 PM »
I just don't want to ever have to deal with that again. Doubling the mounting bolts should make the weak link somewhere else. Everything else were things I was planning on attacking this month. It just unexpectedly doubled.
« Reply #9 on: April 04, 2012, 09:03:46 PM »
Also, I did hear a loud pop launching up onto a path last weekend. I know what the pop noise was... initially. The speed bump must of popped the last bolt. :whistle:
« Last Edit: April 04, 2012, 09:04:27 PM by 1995yj »
« Reply #10 on: April 04, 2012, 10:16:49 PM »
maybe they broke b/c you have poly bushings. btw, if i'm not mistaking those bolts saying 8.8 are equivalent to grade 5, i think the 10.9 are the grade 8 similar strength (or 10.8, can't remember exactly).
« Reply #11 on: April 04, 2012, 10:40:56 PM »
Probably broke from me driving it stupid. Thanks for giving me the benefit of the doubt. I got that suspension and I have this dumb impression that it'll hold up.  :truck:
« Reply #12 on: April 05, 2012, 06:04:36 PM »
My guess is that the bolts might have loosened a little and that's why they snapped off.  What grade were the original bolts?
« Reply #13 on: April 05, 2012, 07:07:12 PM »
« Reply #14 on: April 05, 2012, 07:12:45 PM »
The top of the bolt was 8.8.  What matched closest was (3) M10-1.5x30mm, but they were a few mm shorter. 35mm was too long. Thanks for the grade info, I was wondering what the numbers ment.
