Author Topic: High-Amp Alternators  (Read 6285 times)
« on: August 08, 2012, 04:59:33 PM »
Well, I'm in need of one again as my rebuild had a bad bearing and I've had it apart for a few months and haven't bothered to order new bearings.  I might as well now just get a new one.
I saw there were a few more options now.
My old one was modded to 170a from this seller.  It lasted 2 years, IIRC.
http://www.ebay.com/itm/120753198798?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_1269wt_1041
A bit cheaper and looks better but still a reman.  It's an OE 160a.
http://www.ebay.com/itm/190470444766?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_2704wt_1041
A new 200a.  It's new and it's 200a?
http://www.ebay.com/itm/251124640984?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1438.l2649#ht_2377wt_1041
Re: High-Amp Alternators
« Reply #1 on: August 08, 2012, 05:05:05 PM »
Have you considered getting a Premier Power Welder with their alternator?  It should be a good one.
« Reply #2 on: August 08, 2012, 05:09:35 PM »
I want to keep the cost below $150.  Although I would like a welder.
« Reply #3 on: August 08, 2012, 11:37:09 PM »
that 200A one is very tempting, i did a search for the Part# and comes up as reman, not sure if the p/n is for a new one or exclusive reman but i did not find it as new anywhere else.
it is a good price regardless, but if it's reman is cheaper at Amazon
http://www.amazon.com/Denso-210-0147-Remanufactured-Alternator/dp/B0018RBXB4/ref=sr_1_1?ie=UTF8&qid=1344490278&sr=8-1&keywords=DENSO+2100147
« Reply #4 on: August 09, 2012, 12:02:55 AM »
Well, it say's it's new and not a reman. and the seller is 99.7% with a green star.
I found a different listing for the same one: http://www.ebay.com/itm/HIGH-AMP-ALTERNATOR-1993-1992-1991-1990-Dodge-D-Series-Pickup-5-9L-Diesel-/251126105312?hash=item3a784844e0&item=251126105312
Strange that most of the listings on Google are for the Reman though.
JerryBransworth
« Reply #5 on: August 21, 2012, 04:33:54 PM »
Hey Jeffy,
I installed a 136 amp alternator, upgraded the big 3 wiring to 4 gauge, and popped in an Optima Yellow Top at the same time. I got the alt brand new for $100 from 'Penny Pincher Auto' in Phoenix, AZ and it came with a lifetime warranty. I can't remember the brand off the top of my head but I still have the packaging in a storage unit so I can check for you in the next week or two. I was also looking at the 160+ options and hoped to make a junkyard find, but this option ended up making the most sense at the time. I needed to upgrade because I'm running a 600w (rms) amp to drive 2 300w rms 10" subwoofers built into the backseat and a 1000w power inverter mounted under the dash, and it was making my headlights dim and flash at night and would drain the battery every couple weeks. The new one's worked perfectly for me for the past year-and-a-half since I installed it; no more dimming headlights, poor starts, or anything electrical related. I also tracked fuel mileage before and after. I installed the 4.0L TB at the same time as the amp, and the combination of the two resulted in a mere .2 mpg reduction afterwards, barely even worth mentioning. Hope that info helps, let me know if I can be more descriptive.
« Last Edit: August 21, 2012, 04:35:57 PM by JerryBransworth »
« Reply #6 on: August 29, 2012, 02:33:35 PM »
Well, I ordered one.  It's still cheaper then the DCC thing.  :wall:
« Reply #7 on: August 29, 2012, 04:28:46 PM »
did you find out if its a reman or rewind?
« Reply #8 on: August 29, 2012, 04:41:47 PM »
It lists it as new and when you go to ask a question it says it's new.  So I'm thinking it's new.  A reman is easy to spot so I'll know once I get it which should be before the end of next week.
« Reply #9 on: September 01, 2012, 06:24:38 PM »
Well, it arrived in a box that was more like a paper bag.  It was pretty beat up.  The alternator was in a flattened cushion of paper.  At least on the "bottom".  Two "problems" I found, one was the plastic isolator was busted.  The thin guard on the back was battered a little in one area.  My other alternator had the same damage on that part.  The plastic part gets replaced with the Jeeps anyway so that's not really a problem.
The alternator is new.  I think they build them there though.  It has a generic "200 AMP" sticker with "Made In the US" on it.  All the parts look new though.  I'll get around to installing it in a few days.
JerryBransworth
« Reply #10 on: September 02, 2012, 01:48:19 PM »
I had to grind down that plastic isolator to fit 4 guage wire and its accompanying ring terminal on mine anyway, and just sealed the finished product up really well with heat shrink to insulate the connection from the housing. ...if that plastic boot around the (+) terminal is the isolator you're referring to.
Good luck with the install.
« Reply #11 on: September 04, 2012, 09:41:29 PM »
So from 75a to 170a and now 200a.
JerryBransworth
« Reply #12 on: September 05, 2012, 03:15:44 AM »
WIN, nice work!
« Reply #13 on: September 10, 2012, 10:56:28 PM »
I'm betting that thats a Alt for a engine with a water to water intercooler and the v-belt is for the secondary water pump.... :)
HMM,,, is my play money account re-charged yet?
« Reply #14 on: September 10, 2012, 11:02:11 PM »
The pulley doesn't go with the alternator.  It's for my Kilby OBA.
