Author Topic: Need help with a couple of issues  (Read 3088 times)
« on: June 13, 2013, 07:41:00 AM »
OK, first thing first...  The Jeep is still running good (it is still acting up a bit after I shut down, let it cool for a bit, and then fire it up again and accelerate under load, but once it warms back up, it runs just fine), but I need your help with the following:
1. I got tired of the blue bulbs in the Jeep, and found among my things a set of brand new OSRAM Night Breakers (yes, these also have a blue tint, but not where most of the light will be generated).  From what I have found online, these are among the best bulbs at putting usable light out in front of the vehicle without blinding oncoming traffic, so I figured I'd give them a try (I bought these a while back while in Costa Rica, but never installed them).  My question is, how the heck do I get the H4 bulbs out of the lamp?  I have aftermarket headlights, by the way (mine are not sealed beam).
2. Yesterday, while coming back to the Jeep after a basketball game, I saw two cockroaches scurrying about in my Jeep.  I guess that's what I get for letting my kids eat in the Jeep...  Anyway, what is the best way to get rid of them?  traps?  Spray the interior?  I know this is not your typical "how-to" question for this forum, but I still need to get rid of this issue...
Felipe
Re: Need help with a couple of issues
« Reply #1 on: June 13, 2013, 08:06:03 AM »
For question 2, I recommend cats.  Natural and chemical free solution.
Otherwise traps would be better to avoid the chemicals sprayed everywhere.
« Reply #2 on: June 13, 2013, 08:16:32 AM »
« Reply #3 on: June 13, 2013, 08:17:25 AM »
#2: just ignore them
« Reply #4 on: June 13, 2013, 03:45:02 PM »
For #1, the issue I have is removing the rubber protector; I'll figure it out tomorrow....
For #2, I did a deep cleaning of the interior, and I will set traps next week, when it will sit in the garage for a week or so after my wife gets her car back from the shop (and, as a direct result, I get my daily driver back!)
« Reply #5 on: June 13, 2013, 04:12:48 PM »
For the bulbs, there a rubber boot.  Take that off The plug can come off as well.  Then there is a wire bracket.  Pinch the ends together and lift.  The bulb should come out.
I thought you didn't have carpet?  The only place they could be living is in the seats.
« Last Edit: June 13, 2013, 04:12:59 PM by Jeffy »
« Reply #6 on: June 13, 2013, 04:52:43 PM »
  #1 just pull that's it.  Way harder to get it back on right.
« Reply #7 on: June 14, 2013, 08:03:11 AM »
I took the carpet out, but put a new one back in...  I took it off to clean it, though, and there was some food under the rear seats (around the seatbelts).
OK, I'll try that one; was not sure that was the right way, and did not want to break it.
« Reply #8 on: June 14, 2013, 09:39:09 AM »
try to rotate it so it will break the bond (to avoid tearing it if you pull). you could get a 1/8 steel rod and bend it, slide under the boot in one spot and then work your way around the housing to "unglue".
