Author Topic: Calif folks If you saw this jeep  (Read 6708 times)
« on: June 18, 2013, 04:22:23 PM »
Its my sons, caught fire, bunch of oil in the engine bay.  Has an Automatic and that had just quit working.
« Last Edit: June 18, 2013, 04:22:43 PM by grumpygy »
Re: Calif folks If you saw this jeep
« Reply #1 on: June 18, 2013, 04:57:14 PM »
that sucks. hope he is ok and the fire didn't do too much damage.
« Reply #2 on: June 18, 2013, 06:16:25 PM »
Well he should have had a Fire Ext.  Since he was on his way to work at the fire Department.
« Reply #3 on: June 18, 2013, 08:54:52 PM »
Where's that?
« Reply #4 on: June 18, 2013, 10:28:50 PM »
Bakersfield area.
« Reply #5 on: June 19, 2013, 12:24:37 AM »
So that's like 58 between Barstow and Bakersfield.
« Reply #6 on: June 19, 2013, 10:52:03 AM »
Could be 99, 58 or Rosedale Hwy.  But could be 58  going into Bakersfield from Keene.
« Reply #7 on: June 19, 2013, 03:37:43 PM »
99's usually 4 lanes and doesn't get that close to the mountains. Rosedale Hwy is a strip of 58 that's all in the city.  Looks a lot like 58 outside of Tehachapi
So did he figure out what happened?  Transmission overheat and puke onto the engine?
« Reply #8 on: June 19, 2013, 04:11:01 PM »
Haven't heard yet.
« Reply #9 on: June 19, 2013, 10:18:17 PM »
Well he has traced it down to a breather or the trans dipstick tube.  Both in the same area.
« Reply #10 on: June 20, 2013, 02:16:13 PM »
What's the fluid level of the transmission?  The breather on the firewall next to the battery is for the transfer case.  It would be 1000x more likely the transmission overheated then the transfer case.
« Reply #11 on: June 28, 2013, 10:00:45 PM »
It was the trans and its toast.  Is there a good automatic that would be a good replacement for what he has.
« Reply #12 on: June 29, 2013, 12:41:02 PM »
Yes, the TF904 aka; 30RH which happens to be the stock transmission.
« Reply #13 on: June 30, 2013, 08:43:15 AM »
His is a newer jeep I believe it has the 4 speed automatic.
« Reply #14 on: June 30, 2013, 11:32:03 AM »
The stock 4 speed auto in the later TJ's isn't very suitable for it. If he is good at wrenching a AW4 out of an XJ is a much better choice.
The 4 speed auto has caused a lot of vehicle fires in JK's
