Author Topic: Temperature Gauge  (Read 17368 times)
Temperature Gauge
« on: September 24, 2020, 09:01:09 PM »
I replaced the T-stat with and the temp sending unit. But the gauge still reads just barely above 100. I used a heat gun and the top of the radiator reads between 190-195 which is where it should be with a 195 t-stat.
So Im guessing the gauge is bad.
I don't want to tear the dash out to replace it with a factory one.
I was thinking of adding a gauge to my dash bar.
Any recommendations on what brand? I really like the Stewart Warner Heavy Duty look. It shows just one wire going to the sending unit. It recommends not removing the factory sending unit. The factory unit has 2 wires? How do you tell which one to piggy back into?
Is one a ground and one power?
Re: Temperature Gauge
« Reply #1 on: September 25, 2020, 06:36:58 PM »
I swapped out the temperature sending unit and now the gauge moves, but it's reading about 215 with a 195 T-stat.
It's a Autozone brand sending unit.
Maybe I'll see if the dealer has one?
« Reply #2 on: September 26, 2020, 12:59:32 PM »
Hmm, I haven't had to change mine.  With the electric fan mine hovers just below 210.  Might try a different brand.  I'm sure they're all made pretty cheaply and aren't very accurate.  Maybe Autometer or Bosch has one?  I'm sure the mopar one is a third party as well.
Offline 95 Lowbuck
« Reply #3 on: September 26, 2020, 07:56:21 PM »
I’ve found a big difference between the average auto store sending unit,
and a factory one.
The average one I bought was too long and actually got crushed by installing it.
Like Jeffy said, the Mopar ones are probably 3rd party, but it is at least made to their spec.
« Reply #4 on: September 26, 2020, 10:03:23 PM »
and a factory one.
This is the second one I bought from Autozone. When I pulled the one out to replace, I noticed that it was really dented as if something happened to it. It did not look like the brand new one. Maybe it's to long??
I'll get one a Mopar one and see what's up.
« Reply #5 on: October 03, 2020, 01:16:07 PM »
The Mopar one fixed the issue. Now the gauge reads correctly.
The only difference I could see is the Mopar one has thread sealer on the threads. So it gets tight faster, so I didn't have to run the sensor all the way in. It sticks up about a 1/4 inch more.
