Author Topic: best plugs and wires  (Read 6937 times)
01amberfirewv
« on: May 29, 2006, 06:21:24 PM »
I think I am going to change the plugs and wires, should I stick with champion and mopar?
Guardian7
« Reply #1 on: May 29, 2006, 06:40:35 PM »
Champion's are crap, stick with Autolite, bosch etc..
« Reply #2 on: May 29, 2006, 07:10:51 PM »
I've always used something other then Champion which are usually OEM.  I've run Accel U-Groove, Bosch Platinums, etc... and now standard AutoLites.  I've heard Champion truck plugs are pretty good.  Has to do with the copper.
I haven't had much luck with Platinum's.  I've read others don't have good results either.  One plug I'd like to maybe try is a NGK Iridiums.  THey are $$$ though.
Guardian7
« Reply #3 on: May 29, 2006, 08:44:49 PM »
All the new trucks seem to be using Iridiums and they claim their good for 90K which may account for the big $$ they get. A few years ago while working as a mechanic for NASA Ames Dryden they provided Champion plugs for all our tune-ups and they would die really fast! Champion may have better performance grade plugs but I will never waste my money trying them.
Erik
« Reply #4 on: May 30, 2006, 10:10:08 AM »
my jeep runs MUCH better with champion truck plugs than it did with any other brand I've ever tried.  using accel plug wires also.... plug wires can get expensive but i notice no difference between the $39 accel's and the $80 msd's......
jeepers
« Reply #5 on: May 30, 2006, 03:12:28 PM »
Quote from: "Erik"
I have had the very same experiance with Champion plugs, and have found that spending $$$$$ for plug wires is a waist of money also. (unless ya got to have pretty colors  :roll:  )
« Reply #6 on: May 30, 2006, 03:26:41 PM »
Quote from: "jeepers"
You won't notice any difference unless you start increasing the gap of the plugs.  .035" is the stock gap.  Using the stock gap with perfromance wires will net you nothing.  I currently run my gap at .065" with no problems.
YJmechanic
« Reply #7 on: May 30, 2006, 03:38:00 PM »
i don't like champions.  At the dealership we pull the champions and run ngkr's.  I run the standard autolite resistors.  I do use the ngk iridiums in my suabru but that is a totally different animal.  My jeep probably has under 200hp and the subie has 400hp and needs the high fire plugs but the jeep may be a waste for them.
01amberfirewv
« Reply #8 on: June 15, 2006, 12:36:39 PM »
Wal*Mart didn't have the standerd or coper autolite plugs for Jeep but did have platnums.  Are they any good?
« Reply #9 on: June 15, 2006, 12:42:25 PM »
I don't think you'll see any benifit with platinums.  Sometimes platinums can cause problems as well.
SMC4WD
« Reply #10 on: June 15, 2006, 02:07:17 PM »
On my Nissan, the only thing that runs good, no great, are the NGK Iridiums.  A sports car, or sporty engine loves those things...
On the Jeep, I just put in the NGK V-groove.  Now I haven't driven it since I put those in, so let's hope that there's a noticable improvement over the Champions that were in there for about 2-3 years...
I'm running a MSD ignition so I gapped them at .40, although I heard that I should have gapped them at .50.  So we shall see...
01amberfirewv
« Reply #11 on: June 16, 2006, 10:02:33 AM »
I got MOPAR wires and NGK vpower plugs.  What is the required gap size and how many lbs should I trq the plugs to?
Erik
« Reply #12 on: June 16, 2006, 12:43:35 PM »
.035 gap
i usually just snug them and then give them about 1/4 turn at most
« Reply #13 on: June 16, 2006, 01:43:41 PM »
Quote from: "01amberfirewv"
Look at the Emissions sticker under the hood.  It will tell you the propper gap.  As for tightness, I do it by feel.  (Seated + 1/8 turn)
YJmechanic
« Reply #14 on: June 17, 2006, 03:27:38 PM »
that's a pretty good combo, you should be fine.
