Author Topic: *** Introduce yourself here! ***  (Read 634520 times)
jazz
Re: *** Introduce yourself here! ***
« Reply #1335 on: August 01, 2011, 09:37:24 PM »
Hello to all my name is Jeff and I've had a few jeeps in my day started with a 1978 cj7 levis, 1989 xj ,1995 yj  and 2006 tj  picked up 1997 tj with a bad engine working on that now .
Offline disruptstudios
  • Newbie
« Reply #1336 on: August 20, 2011, 11:46:57 PM »
hello. my name is Jonathan. im excited to finally he a member here after days of reading and checking for registration to open again. the wealth and quality of information here is better than any jeep forum im been to yet. i look forward to contributing and learning all that i can.
i am in the process (started today) of swapping motor and trans out of a 97 tj into my newly acquired 1991 yj. no one has been able to answer my question any where else but i feel certain ill get some support here!
GuidoYJ
« Reply #1337 on: August 22, 2011, 01:52:46 AM »
Greetings from Southern Oregon.  I finally got my Wrangler after wanting one for so long.  Its a 1995 YJ with the good old 2.5.  I am apparently the 7th owner and am ready to start banging my head at the options to hop it up.
I am just looking at  making it a peppy daily driver that will go most places I decide to go.  If you know anything about Southern Oregon, you know that can be quite a task.
I look forward to the years of building and rebuilding. Hopefully this will be my one place to go for rebuilding info.
Thanks.
T.T.W
« Reply #1338 on: August 22, 2011, 07:43:09 PM »
Hello all. New to the site. Didnt ever think you people were going to let me in. I own a 94 Yj with a 2.5. It may be underpowered but it also lasts for ever. Mine has 286,000 and change.
crowsnestguy
« Reply #1339 on: August 24, 2011, 09:30:06 PM »
Hi all my name is Richard and i am new here. Thought i would check in and say hi.
Have had a 1995 YJ for about a year now. Bought it with a 4" lift, and 33 x 12.5 tires already installed but there is lots of things for me to still tinker with still. In the past i was a Samurai,and Tracker guy but now i am lovin the Jeep!
Catch you on the forums....
95yjman
« Reply #1340 on: August 29, 2011, 12:02:07 AM »
Welcome guys!
cyberdyke
« Reply #1341 on: September 01, 2011, 03:59:41 PM »
Howdy,
I'm new to the forum but not new to wheelin'.  I have been a member of the mailing list for the 4bangers for many years and I've been wheelin' since I bought my first Jeep '99 Cherokee.  Which we liked so much we decided 6 moths latter to trade our Nissan 4x4 p/u in on a '99 Tj.  Wheeled in Moab in '01 and Idaho and Washington in '99, 00 and 01 and of course right here at home in Portland, OR.  Haven't been out in a long time with the price of gas and now that my baby is getting old.  :(
My TJ is a 4 banger manual with a 2" spacer lift, gas tank skid, side bars and a power steering skid.
Nicks92jeeper
« Reply #1342 on: September 04, 2011, 01:20:35 AM »
Just wanted to introduce myself. My name is Nick and I have had a 92 Jeep Wrangler for about a year now. I have had to put a LOT of work into it due to the last owner neglecting it. Rebuilt the rear frame and some of the front frame from rot, new head gasket, starter (after 2 days of owning it) and right now I am repainting the beast a gunmetal grey color. I cut out all the rust and welded in 20 gauge sheet metal and she came out pretty well for a first timer. I am treating the frame and under side of the tub with POR 15 and the inside of the tub with Herculiner. Repaired the driverside floor from rot.
Now the fun stuff.
I installed the 4.0 throttle body and after installing the housing for one of the sensors it dropped down from 4500 rpm to normal rpm.
When I was doing the head gasket I ported and polished the head. The shop had to plain down the head 15 thousands to get it flat again.
With the head off I ported out the intake manifold as well as the exhaust manifold and on the intake I matched up the TB plenum opening. Lots of carbon built up on the valves, springs, rockers and pushrods so I cleaned them all up and reset the valves for proper seal.
New Raptor muffler because the old one rusted in half.
Double platinum plugs.
MSD ignition coil.
I think that is all for now and I will post plenty of pics later.
Nicks92jeeper
« Reply #1343 on: September 04, 2011, 01:22:52 AM »
Forgot to say in my last comment that my Jeep is a 4 banger (haven't sent in for the attachment kit yet to make it a v6) (Sarcasm) I have 31s and a 2.5 lift from frame to body.
jeremy04949
« Reply #1344 on: September 04, 2011, 04:08:28 PM »
Hi ya'll I just joined today. My name is Jeremy. I have a 2004 Jeep that I bought in 2007. Currently I have a the following accessories: Power Steering Guard, Rear Tail Light Guard, RC 2.5'' lift, 31'' Duratracs on Granite Alloy G9, Currie Anti-rock sway bar.
« Last Edit: September 04, 2011, 04:09:32 PM by jeremy04949 »
Tom95YJ
« Reply #1345 on: September 04, 2011, 07:09:10 PM »
Hey, Guys amd Gals ?    I'm new here, But not to Jeeps.  I've been wanting to register here for a long time now and was finally able to thanks to Jeffy on Jeepforum.   I love my 4banger Jeeps that I have owned in the past .  I am currently Jeep-less but thats until the spring and when I will be  getting another 4banger YJ or TJ.
My first Jeep was a 98 TJ se  It was stock for about a week before It went under the knife.  Then it was treated to a 4" lift, Sye, 4.88's F&R lockers and 33's. over a period of a year or so.   About 2 years after I bought the TJ it had  decided the s # 3 piston  looked better outside of the block.   I had a long block installed in it that was bored .30 over,  and had a Mopar Purple Cam in it with Yella Terra rockers , and a Pacesetter header and 19# ford injectors , 4.0TB and spacer, Intake manifold was bored to match tb opening, eletric fan convierson.  Which really brought it to life.   Sadly I was unable to enjoy it for much longer after that because of financial issues .   I had sold the TJ for 3,000 more than I owed the bank and picked up a XJ that I had hated with a passion I had the XJ for 6months and stumbled upon a 95YJ se for sale for $2400  so I bought that and sold the XJ.    The YJ was modified over a few years  with a 4.5" RE Xd lift, 1" bl, 4.88 gears and lockers with a XJD44 swap in the rear, SYE, and 33's, 4.0TB/spacer, Intake manifold was ported to match the tb, and a eletric fan .  I had it parked for a a year after I moved to TX from Md and got out of Jeeping.  I sold the Jeep last year and have been lost ever since.  Now I am living in Utah about 2hrs north of Moab .  So I've been saving for a Jeep to get me back in the saddle again.
Pics of old rigs :
« Last Edit: September 04, 2011, 07:12:22 PM by Tom95YJ »
« Reply #1346 on: September 04, 2011, 07:45:21 PM »
Welcome!
76flh
« Reply #1347 on: September 07, 2011, 05:08:13 AM »
 my name is tracy williams , my jeep is a 1998 tj with the 2.5  and five speed. 2 inch lift with 32x12.50 tires. just found this site and joind. thanks for having me.
catfish33
« Reply #1348 on: September 07, 2011, 01:37:55 PM »
Hello all my Name is Jeremy but EVERYONE calls me Catfish. I used to belong to this board and just recently got back into modding my 97' TJ. It has the 4 angry squirrels with an AX-5 and 4.10 gears. Has a 2" BL and 2" lift in the rear with a  2.5" lift in the front to level everything out. 33/12.50'a on 15x8 black rockcrawlers wheels. Recently changed my exhaust from the Head to the rear. Added some "flush mount" looking tail-lights http://cgi.ebay.com/ebaymotors/_W0QQcmdZViewItemQQitemZ140519227711. Oh and trimmed my stock flares by 1.5" Other than the obnoxious tick tick tick she runs like a champ and takes me where I want to go.
dobson
« Reply #1349 on: September 21, 2011, 08:23:46 PM »
hey all im chris with a 98 Wrangler, pretty much stock but plan to start moding it soon.
