Author Topic: Fuel Issue  (Read 4094 times)
cromwell
Fuel Issue
« on: January 06, 2007, 05:07:17 PM »
Well I picked up my Jeep from the port and did notice a couple of issues. My speedo was off by about 5 MPH.  My wife was in front of me traveling at 50 and the Heep registered 45. So It looks like I will be purchasing a new speedo gear. Second is it drank gas!!! I used a half a tank just to travel approx 65 miles. So I will be doing a tune up. Good thing I ordered plugs, wires, rotor and cap.  Is there anything else I should be looking at/for the Heep has just over 92K on it.  The only code that comes up is 65 for high pressure power steering.
Tony
lanulos89
Fuel Issue
« Reply #1 on: January 06, 2007, 07:45:54 PM »
with 30" tires the speedo will be off by 5 mph, and jeeps get crap millage, i get like 150 to a tank of gas, so your jeep doesnt sound out of the ordinary.
dangjalopy
Fuel Issue
« Reply #2 on: January 07, 2007, 06:32:01 AM »
I have 31s on mine and its only off by about 2-3 mph at 60mph from stock.
Fuel Issue
« Reply #3 on: January 07, 2007, 11:22:15 AM »
i have 31's and i got about 180 miles on my last tank.. but my current one is going to be less.
15 gallon tank.. and that was when i had a gas vent leaking...
Fuel Issue
« Reply #4 on: January 07, 2007, 02:19:28 PM »
Swapping the speedo is simple.  Check the DIY for the tooth count and install info.
As for mileage, I can usually get 220miles out of a tank.  I don't trust the gas gauge and have a few gallons left.  I've had 300 miles on one tank, although I've got a 20 gallon tank.
  • Poseur ExtraordinaireŽ
Fuel Issue
« Reply #5 on: January 07, 2007, 05:05:23 PM »
I have 31's and am 5 mph off at 70 (really going 75...verified on the GPS).
That is horrible mileage...I'm more in line with Jeffy...in the 250 range per tank and I usually have more than a gallon left in there...stupid gauge....
Fuel Issue
« Reply #6 on: January 07, 2007, 05:50:50 PM »
I just filled up.  With 14 gallons I had around 230 miles...
Tall Boy
Fuel Issue
« Reply #7 on: January 07, 2007, 09:29:54 PM »
I drove close to three hundred on a full tank with my 19 gallon tank. I usually also have gas left over still in the tank.
cromwell
Fuel Issue
« Reply #8 on: January 08, 2007, 04:47:05 PM »
I use to get between 15-20 miles per gal or about 250-300 miles and that was while I was in Wyoming.  Now that I am in Ireland and at sea level, it gets far less then the norm.  And with gas prices here at approx $5.20 a gallon if I can not figure it out I will have to get rid of it and that is something I do not want to do.
So the first thing I am doing is replacing the plugs, wires, cap, and rotor, along with the air filter.  The entire exhaust system along with both o2 sensors were replaced about a 18 months ago, so hopefully they are still good.
And for those who would say just get a DD. Insuring and registering vehicles in Ireland is not the same as in the states.  Here you are only allowed to insure one vehicle per driver.  So since my wife has the other vehicle it is either fix this issue or I will have to say goodbye to my friend.  And since I am over here that means to the crusher.
Tony
Jaggedfel
Fuel Issue
« Reply #9 on: January 08, 2007, 05:07:56 PM »
Please dont send you baby to the crusher!  Bad gas mileage and spluttering and such on mine was caused by my family not putting the plug wires right on mine after changing it.  Make sure they're seated properly and the plugs are still good.  Champion plugs are also known to be the best for them.  The platinum junk doesen't work well for these motors.  Also, check your OBD II codes if possible, I dont think it should show any though.  Finally, if all else fails, can you take the insurance off of it and then put it back on it at a later time (once you get the issues fixed and upgrade it like you want it?)
cromwell
Fuel Issue
« Reply #10 on: January 08, 2007, 05:31:01 PM »
Jaggedfel,
  If it is not insured then it can not be registered.  The plugs that I have alway used are splitfires since that is what came in it when I bought it 11 years ago.  The only code it is throwing is a 65 for high pressure power steering and that is another issue I have been having trouble tracking down.
Tony
Tall Boy
Fuel Issue
« Reply #11 on: January 08, 2007, 07:29:54 PM »
High pressure power steering? Since when does power steering have a sensor to it, in a Jeep? I swear, I bought my Jeep because it was stripped of all that mechanical mahambajamba. My reservoir has no sensors to it.
 I got an aquaintance in England who moved from the states and he rides a motorcycle there.
Fuel Issue
« Reply #12 on: January 09, 2007, 08:45:38 PM »
i believe there is a sensor in the line
Tall Boy
Fuel Issue
« Reply #13 on: January 09, 2007, 09:55:05 PM »
I looked in my manual and there is no code 65 in the dtc's for generic tool p code. it goes p0030, p0036 then to p0106 and on from then.
Other than that, there is a power steering system analyzer tool to check pressure. Low pressure should cause hard streering or momentary increase in effort to steer, or the wheel will stick and bind. Thats what my fac. manwell says.
 I used to put the front end on ramps and burp the system by turning the wheel to a fro, I think. with the cap off, maybe.
cromwell
Fuel Issue
« Reply #14 on: January 10, 2007, 01:43:09 PM »
Tall Boy,
 I believe there are more sensors on a TJ then a modern airplane.  If you wanted less sensors you should have bought a CJ.  Just kidding.  As for the code 65 in my FSM it is on page 25-6 and can be either a 73 (hex code) , 65 (Mil code) , or a P0551 (Generic Scan Tool Code)
Tony
