Author Topic: rear end gears.  (Read 2673 times)
WillyGrubbs
rear end gears.
« on: March 08, 2007, 04:07:09 PM »
Does any one know what rear end comes in my 89 YJ stock?
Is it the Dana 35 or the Dana 44-30spline axles.
I need a new differential cover because the filler hole nut is rusted in and I need to change the gear oil.
Thanks
Re: rear end gears.
« Reply #1 on: March 08, 2007, 04:55:53 PM »
WillyGrubbs
Re: rear end gears.
« Reply #2 on: March 08, 2007, 07:11:44 PM »
thanks, you are very helpful.
Re: rear end gears.
« Reply #3 on: March 09, 2007, 07:32:36 AM »
On the Dana 35 the fill hole has a rubber plug.  If you have a metal screw-in plug maybe you have some other axle.
Re: rear end gears.
« Reply #4 on: March 09, 2007, 11:13:00 AM »
1987-1990 used a standard metal plug.
Re: rear end gears.
« Reply #5 on: March 09, 2007, 12:32:01 PM »
Ah... always something new to learn.
