Author Topic: INTAKE BORE  (Read 2402 times)
dirtyjeep95
INTAKE BORE
« on: March 19, 2007, 05:54:41 PM »
if you put a 4.0 throttle body from an xj on a 2.5 do you have to bore out the hole in the intake? sorry, if it's a dumb question but i'm new to this jeep thing
Re: INTAKE BORE
« Reply #1 on: March 19, 2007, 06:08:52 PM »
You don't have to, but it will be a bottleneck if you don't.
Re: INTAKE BORE
« Reply #2 on: March 19, 2007, 06:11:52 PM »
I did not do this when I put mine on, thought about it but did not know if it was worth the trouble.  Do you just remove the intake mark a pattern and grind away?
dirtyjeep95
Re: INTAKE BORE
« Reply #3 on: March 19, 2007, 06:15:35 PM »
how much bigger is the hole in the 4.0 compared to the hole in the 2.5 intake?
Re: INTAKE BORE
« Reply #4 on: March 20, 2007, 05:27:11 PM »
I guess this thread died, I still would like to know if it is worth the trouble to bore the intake to match the larger throttle body and spacer?  :confused:
Re: INTAKE BORE
« Reply #5 on: March 20, 2007, 05:38:15 PM »
id say it is.. but my jeep is too old to do this mod so i don't know form my own experience.
YJmechanic
Re: INTAKE BORE
« Reply #6 on: March 21, 2007, 06:24:32 AM »
in the long run it is worth matching your intake but probably only if you have the need for that kind of air.  if you are running a mostly stock setup then i would just put it on and you're good.  if you have your motor pretty hopped up like mine then it would be worth it.  i would say if you don't have a full exhaust and intake with fuel upgrades it is probably not worht it to you.
Offline dexetr30
  • 4BangerJP.comŽ Donator
  • Aloha Mr. Hand!
Re: INTAKE BORE
« Reply #7 on: March 22, 2007, 06:30:38 AM »
Has anyone ever done this and had negative effects? I've been thinking of ripping my tb off and grinding some myself. Only problem is that I know the aluminum from the intake will clog the stone on the die grinder. Anyone have any remedies for this?
Re: INTAKE BORE
« Reply #8 on: March 22, 2007, 12:39:19 PM »
The negative effects would be getting too much air and causing air/fuel problems. (ie., hickups/missfires) It will probably move your powerband further up the RPM range so you might lose some low-end.
Some people use a 2" sanding drum.  Some people have used die grinders or even a Dremel.You could also use a slapper wheel to finish it off and make it round again.  It might be worth it to try and taper the lip some and see if that does anything.
wrangler387
Re: INTAKE BORE
« Reply #9 on: March 22, 2007, 07:06:08 PM »
I used my air die grinder and a carbide burr on mine. I think it is worth it. Atleast taper it like jeffy said.
