Author Topic: 2" motor mounts  (Read 3913 times)
2" motor mounts
« on: April 07, 2007, 03:51:01 PM »
Does anyone have any experience with these https://shop.browndogindustries.com/displayProductDocument.hg?productId=32&categoryId=4 it doesn't have to be this brand but I am thinking about these instead of a 1" spacer.  The reason is I want to add one of these when I install the SYE http://www.getahelmet.com/bullet/33skid/  I have read that a 1" will be ok but I would like to use the 2" so that I can avoid adjustable upper control arms.  I got a 4" suspension lift and a 1" body lift and I would rather not have to use a CV style rear drive shaft.
jeepboy21
Re: 2" motor mounts
« Reply #1 on: April 08, 2007, 12:51:00 PM »
I just installed a set of Brown Dog 1" MML on my YJ last week.  Def more vibrations but it allowed me to get rid of my xfer case drop.  I just notice the vibration a little more b/c the mounts are beefy and they use poly bushings.  These are very beefy mounts and high quality.  I had one question when I was installing them, I called up, they answered on the second ring and I got an answer right away.  Thats customer service.  Also a tip,  have about 1/2" thick of washers that fit on the MM bolt, you need to shim the passenger side.  Also they say in the instructions that you need to take off the drivers side MM bracket and grind it a little to get the bushing to fit.  I could not get some of the bolts out so I just took off about 1/4" to 1/2" if the bushing for the drivers side to get it to fit.  Second to last tip, soak everything in PB Blaster.  Ok last tip,  on the passenger side MM the MM sits on another mount that is then bolted to the frame.  You need to reuse that bottom mount.
Yellowcritter
Re: 2" motor mounts
« Reply #2 on: April 08, 2007, 10:54:43 PM »
Just a thought, but if you raise the engine 2" your possibly going to have clearence problems with the fan & rad shroud. You might have to go to an electrical fan if you plan on running your AC.
lanulos89
Re: 2" motor mounts
« Reply #3 on: April 08, 2007, 11:29:24 PM »
they are good to use when  u do a body lift.  my question is with the lift how did u elimnate ur xfer case drop with these, that would screw up ur driveline even more , the whole reason u drop it is too keep the ds angle small raising thenginend the tcase again would dfeat the pupose imo
lanulos89
Re: 2" motor mounts
« Reply #4 on: April 08, 2007, 11:31:46 PM »
unless you have a sye but if u do why wouldnt you of taken on the drop kit already
Re: 2" motor mounts
« Reply #5 on: April 09, 2007, 05:42:33 AM »
Well I do have an electric fan so raising the motor will not affect that, and I have not installed the SYE yet.  That tcase skid adds 2-3" of clearance and with lifting the tcase it will really change the angle, so i figured 2" of motor lift would put it back around the same angle?
lanulos89
Re: 2" motor mounts
« Reply #6 on: April 09, 2007, 08:07:02 AM »
how you figure by raising that i'd think it'd make the angle worse??  just because you raise the motor it isn't gonna cock the t case like you think,  i dont think it will at least.  i think by doing that you are asking for more trouble.  anyone agree disagree?
Re: 2" motor mounts
« Reply #7 on: April 09, 2007, 08:41:27 AM »
Lanulos, take a pen or something similar and pick one end up, the other end points down a MML is not as drastic but does the same thing.  I know that the tcase skid requires a 1" MML and I read one install write up that they used 2" of lift to a better driveline angle but others have used the 1".  Really I was wanting to know if any one else had used a 2" lift they seem to be kinda new or at least old and unused.  I will most likely use the 1" and should be ok, the guy that used the 2" of space had a CV driveshaft and they seem to require a better angle than a standard driveshaft (non slip yolk of course).  To change the subject from MML to tcase skids does anyone have a tcase skid, got any info for me???
lanulos89
Re: 2" motor mounts
« Reply #8 on: April 09, 2007, 11:10:29 AM »
ok i see what your saying my friend has 1" lift mounts and they work fine tho he has a sye
lanulos89
Re: 2" motor mounts
« Reply #9 on: May 15, 2007, 07:52:37 PM »
ok yea i kno i criticized at first about this idea, but more and more i thought a bout it the more it made sence  :wall:
so i ordered the jks lift blocks put them in and took out my skid spacers, works like a charm sry i doubted you.  def reccomend it to people
Re: 2" motor mounts
« Reply #10 on: May 16, 2007, 01:07:10 AM »
Did you have to drill out the stud on the spacer, too?
lanulos89
Re: 2" motor mounts
« Reply #11 on: May 16, 2007, 04:54:25 AM »
on the passengers side mount i had to take off the bottom plate and grind the stud out and re drill the whole, yea was a pain in the a$$ but it was worth it for the extra ground clearance
Re: 2" motor mounts
« Reply #12 on: May 16, 2007, 09:41:58 AM »
I've used 1" MML's from www.goferitoffroad.com , good affordable product.  I've seen the 2.5L raised as much as 3", but I wouldn't raise that much weight that high up.
Re: 2" motor mounts
« Reply #13 on: May 16, 2007, 12:54:04 PM »
Did you check the review I did?  Was it helpful?  Using a drill press make the removal easy.
lanulos89
Re: 2" motor mounts
« Reply #14 on: May 16, 2007, 07:31:22 PM »
haha no didnt even think to look at the reviews  :rant:  . oh well i got the stud compltly out, oh and now i broke a record tore my motor mount in less that 48 hours
