Author Topic: Rocker guard brand?  (Read 3289 times)
Liljeepz
Rocker guard brand?
« on: May 06, 2007, 05:14:34 PM »
I'm looking to get some rocker guards for my TJ, any one suggest any good brands or what I should look for when buying them? I don't want to spend a fortune on them but I don't want junk either... some where in the middle. I was thinking about getting some with a sliding bar welded on them, but that's up in the air right now.
Re: Rocker guard brand?
« Reply #1 on: May 06, 2007, 06:20:23 PM »
I like Kilby Enterprises stuff.  I know the owner and he makes sure they are up to a pretty high standard.  There are many knockoffs out there though.  Lots of inferior or copycat stuff that sometimes is cheaper but you may or may not get quality.
I do like rockers that have a nerf or step built into them.  This keeps the big stuff off the body and gives you a step to get in.
« Reply #2 on: May 06, 2007, 06:31:38 PM »
Make sure whatever you get ties into the body mounts.  There are several brands which are only attached to the sheetmetal.
« Reply #3 on: May 06, 2007, 07:01:03 PM »
Just as or more important, you want the bolts inside to use brackets an not just large washers.  With a impact at 45* to the edge, it will try to twist the rocket and pull the bolts out at the top.  I've seen this happen first hand with Off Your Rockers on a TJ.  It wasn't a pretty sight.  Left a 1/8-1/4" gap and twisted the rocker and body.
I've seen some nice home made 1/4" L channels used for rockers that works well if you're on a budget.
« Last Edit: May 06, 2007, 07:03:22 PM by Jeffy »
« Reply #4 on: May 06, 2007, 11:51:39 PM »
I peronally like the PSC rocker knockers, they use the body mount and have the slider bar for $300ish. I'm thinking on going that route myself.
Liljeepz
« Reply #5 on: May 07, 2007, 01:52:58 PM »
I like those a lot and there just a little over what I was wanting to pay... I think I will go with those. I like the kilby but there to much money, I don't want to spend $545 on just rocker guards. I do plan on getting there gas tank skid when I scrap up more cash.
Thanks for the info guys!
« Reply #6 on: May 07, 2007, 03:55:43 PM »
These are the ones I'm buying, but their TJ model doesn't attach to the body mounts if that's an issue for you.
http://www.shrockworks.com/Jeep-YJ-Rock-Sliders-Rocker-Guards-Rocker-Protection-Rock-Rails-pr-16173.html
Liljeepz
« Reply #7 on: May 07, 2007, 08:17:57 PM »
Old Jeep, those where the ones I was looking at for the last year, I do like the idea of mounting them to the body mounts, I'm not going to be a rock climber or any thing like that just a trail rig, but it just sounds stronger. There about the same price too.
Greatwhite
« Reply #8 on: May 08, 2007, 10:45:36 AM »
http://www.lodoffroad.com/jeep_rock_sliders.htm
Seems to be a nice product, secure mounting location on the frame, protects the underside of rocker as well as the side.
« Reply #9 on: May 08, 2007, 02:53:51 PM »
Most have moved away from old school nerfs.  The nerfs do eat up some clearance since it hangs below the body.  (I still run old skool 3" shorty nerfs though.)
« Reply #10 on: May 08, 2007, 06:28:08 PM »
And if you slide them across a pointy rock, it's really easy to get hung up on the support bars.
« Reply #11 on: May 08, 2007, 08:39:59 PM »
That's because you've had you're Jeep since they were cool!  8)
« Reply #12 on: May 08, 2007, 08:57:32 PM »
Actually, since they were uncool...  :lol:  They're kinda cool now though.
« Reply #13 on: May 09, 2007, 05:38:32 AM »
DISCLAIMER: Coolness may vary from state to state.
Liljeepz
« Reply #14 on: May 09, 2007, 03:04:01 PM »
Ya! In one state its even cool to put a block of cheese on your head! Weirdo's! :roflol:
