Author Topic: just got a winch  (Read 7134 times)
nofearblackstar
just got a winch
« on: October 09, 2007, 11:15:27 AM »
just bought a milemarker 9000
i am gona make my own mounting plate and was woundering how this should be done . I wound like it so it cant be unbolted easily as i would not want my new toy to get stolin . any help would be great
Alex
Re: just got a winch
« Reply #1 on: October 09, 2007, 11:48:06 AM »
Well, what is this for?  XJ, YJ, TJ, etc?  I'd just copy an existing mount.  No need to reinvent the wheel.
To keep it from walking off, you could do a few things.  Spot weld all the bolts and nuts in place or you could weld U channels over them.  Some people take 1" lengths of tube but you can still use a socket to get around those.  Another idea is to use non-standard fasteners.  Large torx or allen heads, etc...
« Reply #2 on: October 11, 2007, 08:03:31 PM »
Made my own winch plate out of 1/4" steel.  May be able to add a few tips once you list the model of your jeep.
nofearblackstar
« Reply #3 on: October 13, 2007, 03:26:27 PM »
sorry its a 93
« Reply #4 on: October 13, 2007, 03:46:54 PM »
Not much to it then.  Just measure the 4 holes in the frame.  Then measure the holes in the winch.  Choose your steel thickness and cut some holes.  If you don't buy a C channel or a L plate then you'll need to weld on a front plate for the fairlead then gusset it somehow.
http://wrangler.kicks-ass.net/BumperF.htm
http://wrangler.kicks-ass.net/Fairlead.htm
nofearblackstar
« Reply #5 on: October 13, 2007, 04:16:14 PM »
ok dosnt look to bad at all . ill post pics soon . should be able to get it into my shop early this week .
Always building other peoples truck dosnt leave a hole bunch of time for my own
black99tj
« Reply #6 on: October 17, 2007, 10:55:41 AM »
I made my own winch plate out of 3/16 304 stainless. It's two seperate pieces welded together. There have been times when I was worried about the strength of my plate but it has stood the test of time. Just make sure if you replace bolts to go with grade 8
nofearblackstar
« Reply #7 on: October 17, 2007, 11:52:05 AM »
started it last night . ill try to get pics up . i just tore off my old bumper and boxed in the front of the fram rails .
it all out of 3/16 but is bolted to another piece of 3/16 braced down to the cross member bettween the frame rails .Then the boxed piece is bolted to the frame raild in about 6 spots
dosnt look like anything special but i just wanted it to be STRONG . and i like the way its just boxed with no bumper
Offline jagular7
« Reply #8 on: October 18, 2007, 09:23:14 AM »
Once your get everything installed, re-wrap the cable with some tension on it. Its easy to do with a working parking brake.
Jagular7
nofearblackstar
« Reply #9 on: October 18, 2007, 12:08:27 PM »
ok i will . goin out to the shop right now to finish it up .
nofearblackstar
« Reply #10 on: October 18, 2007, 12:14:55 PM »
befor
after . still needs boxed on the side and mount hooks and mount the fairlead but i thing its gona look nice , plain and simple looking
i mostly boxed it cuz it will look cleaner when i flat fender it , witch should be really soon
let me know what you think
nofearblackstar
« Reply #11 on: October 18, 2007, 12:17:59 PM »
heres another pic just cuz im bored .
nofearblackstar
« Reply #12 on: October 19, 2007, 05:52:53 PM »
DONE
Offline aw12345
    • my jeep picture page
« Reply #13 on: October 19, 2007, 06:36:17 PM »
That looks like it will do the trick plenty beefy
2006 Jeep Wrangler TJ SE
2004 Jeep Wrangler TJ SE
nofearblackstar
« Reply #14 on: October 19, 2007, 06:45:24 PM »
felt like some of it was over doing it but id rather do work now then have one hell of a time fixing whatever brakes .
