Author Topic: found a great deal but worried  (Read 5569 times)
95yj4
« on: October 29, 2007, 03:18:47 PM »
Alright so I talked to a guy the other day and he said he had some 33" tires that he was lookin to get rid of. $600 for all four tires with rims. Come to find out they r 33"x14.5" R15 Mickey T's prettty much new. Still had 25% of the knubs on it. I told him that I would have to think about it cause of my axle. Come to find out his brother has a dana 35, rebuilt, with 4.56 gears and I believe he said auburn posie??? to sell for cheap. Now I'm wondering will this combo work or will it still turn the other axle into a grenade??? I know the 4.56 gear is kinda small but its a lot better then stock. Forgot to mention that I have an auto.
Re: found a great deal but worried
« Reply #1 on: October 29, 2007, 03:29:50 PM »
I'd be a little concerned about running tires that wide on a D35.  Your gears are not the weak spot, the shafts and c-clips are.  The other thing to keep in mind is if you have the clearance to move a 14.5" wide tire around in the wheel wells.  Using a tire that wide is going to require wheel spacers or rims with very little offset - both will put a strain on the axles and bearings.
95yj4
« Reply #2 on: October 29, 2007, 03:46:55 PM »
yeah thats what I was thinkin, just wanted to get some other opinions. Oh and I was wrong, I think he said 12.5 wide. But anyways I was really loookin at the axle more then the tires. Does anyone think that the posie (If I'm correct on that) would tear up the axle with say 32"x10.5"?
« Reply #3 on: October 29, 2007, 04:26:07 PM »
Lockers don't snap D35's.  Side loading of the c-clips does.  Should be OK with 32" tires on a D35, posi or not.
« Reply #4 on: October 29, 2007, 04:37:31 PM »
What is side loading in this context?  Like on a side hill?
Offline dexetr30
  • 4BangerJP.com® Donator
  • Aloha Mr. Hand!
« Reply #5 on: October 29, 2007, 04:54:05 PM »
Side loading is off camber driving... or as you put it "on a side hill." lol.
Like this:
95yj4
« Reply #6 on: October 29, 2007, 05:11:51 PM »
well I really dont do too much trailin, mainly cause its my DD. Even if I do its usually nothin like that.
lanulos89
« Reply #7 on: October 29, 2007, 06:49:15 PM »
600 for 33's and rims used really isnt that great of a deal IMO
95yj4
« Reply #8 on: October 29, 2007, 07:07:14 PM »
well I dont think its that bad cause like I said they're practically brand new. But yeah I really dont think I'm gonna get em anyway.
lanulos89
« Reply #9 on: October 29, 2007, 07:09:12 PM »
my bad didnt see that i saw 25% life left on them
« Reply #10 on: October 29, 2007, 07:32:42 PM »
So lets see...
$15-50 Steel Wheels  = $60-200
So that's $400-530 / 4 = 100-132.50 per tire
Since they are so wide, I suspect they are Bias Belted.  I guess it's a deal IF you really like those tires and that size.
25% of the NUBS does not mean there are 25% left.  Nubs aren't even a part of the tread and usually fall off quickly.  Sounds like there are less then 200 miles on them.
lanulos89
« Reply #11 on: October 30, 2007, 05:49:16 AM »
yea i realize that thanks just didnt see it when i read it over at first
« Reply #12 on: October 30, 2007, 06:09:08 AM »
I say you're full of it.  :crap:
I have yet to see a D35 that snapped at the C-clip. Everyone says that's a weak point but every one I saw that snapped was where the splines met the solid surface of the shaft. Had nothing to do with the clips.
This is where they break, almost always caused by lifting a tire when locked and catching traction under throttle.
Don't believe me? Do a search on google images or photobucket for "dana 35" or "d35 shaft" look at where they break. no splines in any of the pics.....
« Reply #13 on: October 30, 2007, 07:45:41 AM »
The D35 breaks that I have seen in person were all axle ejections from the "button" on the end of the shaft snapping off.
« Reply #14 on: October 30, 2007, 08:38:41 AM »
Sounds like they break both ways, it is just a weak axle design.
