Author Topic: Clutch Question  (Read 1817 times)
Desert Bob
Clutch Question
« on: November 01, 2007, 05:38:22 PM »
My 95 YJ has a slight chatter feeling when I let out the clutch when cold. After the motor warms up it goes away.  However, when I bought the jeep the Master Cylinder reservoir was low so I filled it up.  It has not gone down since then but when I depress the clutch after it has warmed up a bit I feel something through the peddle when it touches the floor - almost like a seal or something being squished.  The clutch never grabs you but it does not seem to be slipping when under power.  I have no problems shifting other than the normal 1st to 2nd stiffness when cold.  Are the two related?  Would replacing the master\slave cylinder be advised or am I looking at a complete clutch/cylinder replacement ($$$)?  thanks.
Re: Clutch Question
« Reply #1 on: November 01, 2007, 05:57:00 PM »
Have you ever flushed the system?  How long has it been this way?  The hard 2nd shift is 100% normal and I doubt it's related.  The hard 2nd is an internal issue with the transmission.  The clutch system is completely separate.  If I was to make a guess though I'd guess the issue would be with the master.  But that's just a guess and you'd really want to localize the issue if possible.
Desert Bob
Re: Clutch Question
« Reply #2 on: November 02, 2007, 10:25:23 AM »
I thought that that master/slave system was sealed in a 95?  I don't see any type of bleed valve so how would you flush the system?
Re: Clutch Question
« Reply #3 on: November 02, 2007, 10:55:15 AM »
Are you sure?  There is usually a worm screw that covers the bleeder hole.  (On TJ's this hold is sealed though.  Unless you have a 95.5 and not a 95.  In which case it could have either.)  The bleeder is not a conventional zerk.
Desert Bob
Re: Clutch Question
« Reply #4 on: November 04, 2007, 02:00:33 PM »
I checked the slave cylinder and while there was no fresh fluid in the area it was pretty nasty.  I just might replace the master/slave just to make sure.  In either case if I have to pull the trans and replace the clutch at least the hydraulics will be good.
Re: Clutch Question
« Reply #5 on: November 04, 2007, 02:28:01 PM »
Since you have an external setup it should be fairly painless to do.  You'll probably want the kit they sell that is ready to go.  Otherwise, you'll have to drill a hole in the slave to be able to fill the system.
Re: Clutch Question
« Reply #6 on: November 05, 2007, 05:44:05 PM »
Just so you know, I have the same issue, and I replaced the whole system (master, slave, and line), and the chatter/slipping when cold continues.  I also just got back from a long trip, and I did notice some fluid coming from that section, but I have not been able to locate what the cause is yet...
Be the way, my slave cylinder was pretty much dead, so I am not sorry I changed the system.
Felipe
