Author Topic: power, power and more power...How do i get it?  (Read 6021 times)
swatsniper1s1k
« on: November 08, 2007, 05:26:01 PM »
Just posting this to figure out how to get some easy and cheap horsepower and torque...
I heard from other forums that tb spacer and 4.0 tb will help, but the spacer basically starves the engine of oxigen because of the cheap intake system. anyone know of a ram air kit for a 91 2.5L? if not i'll have to fabricate one using cold air intake kit with some parts for the 4.o ram air. i have a flowmaster series 40 muffler on my jp now, and noticed some power, but that was out of desperation. muffler blew open on the highway late one night, had to replace it for inspection 2 days later. again any and all power suggestions welcome.
lanulos89
Re: power, power and more power...How do i get it?
« Reply #1 on: November 08, 2007, 07:32:48 PM »
electric fan helps, 4.0 tb dont bother with a spacer, takes away power.  headers, and 19 lb mustang injectors  and a real cool air intake
« Reply #2 on: November 08, 2007, 09:27:53 PM »
Hmm, when did a TPS take power away?
lanulos89
« Reply #3 on: November 09, 2007, 05:39:42 PM »
i felt more power when i took my spacer out as did other people who drove my jeep.  so
« Reply #4 on: November 09, 2007, 05:56:52 PM »
It helps with mid-range torque.  Although it also depends on if you have a 2.5L TBS or a 4.0L TBS and what type.  helix, smooth bore, etc...
lanulos89
« Reply #5 on: November 09, 2007, 07:01:47 PM »
guess your right, i just cant jstify soending 70+ bucks on a hunk of metal that does improve it much, but adds a cool sound
« Reply #6 on: November 09, 2007, 08:15:05 PM »
Ouch, don't spend $70 on it in the first place...  It's a decent mod otherwise.
chrisfranklin
« Reply #7 on: November 09, 2007, 10:41:26 PM »
I may pull the TBS I have out and see if I notice a change.  I am running it below a bored out, 62mm TB and stock tubing/filter and airbox
Torque off-idle is ok.  But midrange, part-throttle operation seems a bit off, like the AF ratio is out of kilter.
dunklervogel
« Reply #8 on: November 10, 2007, 01:04:09 AM »
lemme know your results
because i have a spacer as well matched to a 4.0 tb with the helix bore
i would hope it isnt sapping power but i added both the spacer and the tb at the same time so i just assumed that both increased power.
« Reply #9 on: November 10, 2007, 07:50:35 AM »
i think there was a post on here somewhere where someone when through all the combos of 4l tb, spacer (helex or none) and so on. just a mater of finding it.
« Reply #10 on: November 10, 2007, 11:38:57 AM »
It's shouldn't be.  Although with the helix, it does restrict the air flow some which is why it's recommended to go with a smooth bore or hone out the TBS.  So, in that sense you would have better flow without it then with.  Although your torque curve will also change back.
swatsniper1s1k
« Reply #11 on: November 10, 2007, 04:48:32 PM »
cool i'll take some of these suggestions and try them out next time i go back home from college (car isn't here). i'll probably end up raiding the junkyard, near me there's one with around 15 wranglers. i could probably jack most of the parts you're talking about. might even snag a 4.0 engine, ax15 and transfer case with driveshafts and some beefier diffs.
« Reply #12 on: November 10, 2007, 06:11:53 PM »
wich the yards around me had even 1 wrangler in them. no wranglers to speak of at the local you-pull :brick:
« Reply #13 on: November 11, 2007, 03:05:11 AM »
What do you mean CAR???  Jeeps dont like to be called cars!!!   :nono:
Offline dexetr30
  • 4BangerJP.comŪ Donator
  • Aloha Mr. Hand!
« Reply #14 on: November 11, 2007, 07:31:24 AM »
Yup, it's a Jeep. Not a car. ??? 8)
