Author Topic: Cv Style rear driveshaft  (Read 5105 times)
enginethatcould
« on: January 15, 2008, 05:39:53 PM »
Could a TJ, cv style drive shaft be used on a Yj?
Re: Cv Style rear driveshaft
« Reply #1 on: January 15, 2008, 05:45:46 PM »
For the front, yes.
enginethatcould
« Reply #2 on: January 15, 2008, 05:52:21 PM »
For the front, yes.
What is the main diff in the two for the back?
« Reply #3 on: January 15, 2008, 08:37:23 PM »
TJ's don't use a stock CV/Double Cardon driveshaft stock in the rear.  Now if you're talking about an aftermarket driveshaft for a TJ, then again, it will depend since there are different lengths used for 4.0L's and 2.5L/2.4L's as well as manual and auto.  If it's custom then it will come down to actual measurements.  You'll need to measure the yoke to yoke distances.
enginethatcould
« Reply #4 on: January 16, 2008, 06:56:46 AM »
The driveshaft is on ebay. I'm waiting to get a couple of questions answered. I'm about to put a 4" lift on my yj and was thinking about putting the SYE and cv driveshaft all at once. The item, jeep tj rear cv drive shaft. measures 19.5" from universal to universal when fully extended.  Here is the link- http://cgi.ebay.com/ebaymotors/ws/eBayISAPI.dll?ViewItem&item=200191261585
« Reply #5 on: January 16, 2008, 07:00:33 AM »
If it's the right length, then it'll work on a YJ with SYE.  If you havn't got your SYE in yet, it's going to be hard to figure out what length you need.  Best bet is to get a cherokee front shaft and have it shortened by a driveshaft shop (About $60) once you know your length.
enginethatcould
« Reply #6 on: January 16, 2008, 07:36:14 AM »
Which year cherokee would I need to find?
« Reply #7 on: January 16, 2008, 07:39:52 AM »
Any year will work, you just have to look and make sure that it looks like what is in that picture.  There are a few versions which use a booted CV joint rather than a double cardian.
enginethatcould
« Reply #8 on: January 16, 2008, 08:06:11 AM »
Since we are on the subject, what would be a good SYE?
« Reply #9 on: January 16, 2008, 09:24:46 AM »
ANything but a hack and tap.
Most places sell the OMIX ada SYE, I've installed 3 of them and they are beefy and the kit fits well.
Here's one place to get it.
http://www.performanceoffroadcenter.com/oscommerce/product_info.php?products_id=153
« Reply #10 on: January 16, 2008, 10:03:00 AM »
Wow, that is a good price!
enginethatcould
« Reply #11 on: January 16, 2008, 11:08:20 AM »
Any opinion on a "mega short" SYE? Is it worth the extra money?
« Reply #12 on: January 16, 2008, 11:28:00 AM »
As much flack as the Hack & Taps get, I've never seen one go bad.  Although for the price of a H&T for a YJ ($100 more then a TJ) it doesn't make sense to go that route.
« Reply #13 on: January 16, 2008, 11:38:44 AM »
2 problems with the hack and tap that I've seen.
1) You have to run a flanged CV which eliminates all the savings of a hack and tap because you cannot use a cheap cherokee front driveshaft
2) You still have the extremely weak output shaft on the 231.  A full SYE has a fatter shaft where they tend to snap.
The Full SYE takes care of the breaks which happen here:   I've broke one this way and seen a couple others.
« Reply #14 on: January 16, 2008, 12:02:13 PM »
Are you comparing a stock shaft to a 32 spline Heavy Duty SYE?  Standard SYE's from Currie, Tom Woods, MIT and many others are modified stock shafts that have been cut tapped then heat treated. (They mostly sell HD shafts now though.) They have the 27 spline taper where the speedometer gear goes.  Then there are the larger HD kits. These bump up the thickness at the taper so it's 32 splines and stays the same thickness till the support bearing.  Now there are the Super Slim kits as well.  Those are really nice but you lose the ability to calibrate your speedometer/PCM unless you reprogram the PCM and that can only be done on TJ's, I believe.
Top:32 Spline Heavy Duty Shaft/YJ Stock Shaft/TJ Stock Shaft
Even more 231, 242, 231HD shafts: http://www.4xshaft.com/SYE_detail.html
« Last Edit: January 16, 2008, 12:04:05 PM by Jeffy »
