Author Topic: Hi...Noob here!  (Read 1993 times)
maniactriumph
Hi...Noob here!
« on: February 18, 2008, 06:58:44 PM »
Hello all.   :thumb: I'm new to the forum.  I have a '98 Wrangler with several mods including:
underdrive pulley
hard top
Banks exhaust
safari rack
short shifter
front lock-out hubs
intake
4L polished throttle body
elec fan conversion
some other things I can't recall at the moment...
plus more to come as I win the lottery (wishful thinking)
See ya around  :doggy:
« Last Edit: February 18, 2008, 07:43:23 PM by Jesse-James »
Re: Hi...Noob here!
« Reply #1 on: February 19, 2008, 07:35:56 AM »
Welcome to the forum.  What is an uderdrive pulley?
Re: Hi...Noob here!
« Reply #2 on: February 19, 2008, 12:36:24 PM »
Something you don't find on Jeeps.  It's basically a smaller pulley for say the PS pump or alternator.  Using a smaller pully would slow the accessory down which would allow for the engine not to struggle.  BUT the alternator pulley is pretty small already and you really need the PS pump working at 100%.  You'd be better off getting rid of the clutch fan then trying to scavenge power from a pulley swap.
Re: Hi...Noob here!
« Reply #3 on: February 19, 2008, 12:52:02 PM »
Interesting, never heard of it before. Thanks
Re: Hi...Noob here!
« Reply #4 on: February 19, 2008, 12:55:41 PM »
Oh yeah, you could also slow down the fan/waterpump but you'd want a high volume pump to keep the flow up and then you might run into overheating issues.  Which is why I'd recommend the electric fan.
Offline VA_YJ
  • Now I need a CJ...
Re: Hi...Noob here!
« Reply #5 on: February 19, 2008, 04:07:14 PM »
I agree with Jeffy.  Underdrive pulleys are typically used by drag racers to extract a little extra HP from their engines.  When you're offroad, you're generally running slower, with accessories (fans, lights, winches, etc.), and pushing your steering and cooling systems pretty hard - The total opposite of drag racing.
Re: Hi...Noob here!
« Reply #6 on: February 19, 2008, 05:15:02 PM »
The little 4 pooper has enough ump ofroad its on road at highway speeds where it struggles and a underdrive pulley could help it some. If it works for him why not
