Author Topic: 6-lug 8-lug axles  (Read 1850 times)
JCAUDILL0034
6-lug 8-lug axles
« on: June 07, 2008, 09:17:31 AM »
i was wanting to swap to some heavy duty wider axles to my 98 wrangler.....just wondering what you all think would be the best swap
Re: 6-lug 8-lug axles
« Reply #1 on: June 07, 2008, 09:52:09 AM »
Need more info.......
Willing to go full width? What size tires are you going with? What's your budget?
JCAUDILL0034
« Reply #2 on: June 07, 2008, 11:11:27 AM »
i can go full width or have them cut down like my s-10...going to step up to 35's maybe 37's later after a bigger better lift...money not that big of a problem.......might just buy one axle at a time....figured i would need to run 5.38's or better for the tires
« Reply #3 on: June 07, 2008, 01:30:47 PM »
For 6-Lug, just go with an '84-'91 SJ D44/D44 or D44/M20.  No narrowing required since they're something like 62" up front and 59" in the back.  This would by far be the cheapest option.
Going 3/4 or 1Ton on 35's is a bit much.  You'll lose ground clearance unless you shave the housings.  For something larger I'd go with a D60/14B combo though.  You'll probably pay a premium for a 78-79 D60 but the 14B's are cheap.  You can easily shave off 1.5-2" off the bottom of the 14B without causing other issues.
« Reply #4 on: June 07, 2008, 07:50:52 PM »
Unless you're Moz.....
For 35's or even a little bigger why not do an 8.8/D30? Should even be OK for 37's with chromoly shafts.
JCAUDILL0034
« Reply #5 on: June 07, 2008, 10:33:34 PM »
went and ate with the wifes friend and her man tonight...turns out he is a fellow jeeper and a bronco man he he said he has like 10 or more d60's gets them all from a scrap yard
« Reply #6 on: June 08, 2008, 01:12:46 AM »
Unless you start shaving the D60, it's a bit of a anchor in the rocks.  If you don't have rocks then it's just a shovel.
8.8/D30 won't give you the low enough gears.  Not to mention he wants the stronger 6 on 5.5 or 8's.  Then there's the manual hubs...
JCAUDILL0034
« Reply #7 on: June 08, 2008, 11:06:07 AM »
gonna go look at some of his stuff today.....and see what all it looks like
