Author Topic: anyone know of a common metric size tire around 33x10.50R15  (Read 7830 times)
willbacker45
« on: August 01, 2008, 02:04:58 PM »
lookin for a 33x10.50R15 only three companies make them, BFG, Interco, and Super Swamper and all of those are high $$$$ tires.
i need something a lil more common around that size but i dont think i can do 12.50's
anyone got any ideas??? how bout a common metric around that size?
Re: anyone know of a common metric size tire around 33x10.50R15
« Reply #1 on: August 01, 2008, 02:49:39 PM »
You do realize that 'Super Swamper' is a brand under Interco Tires?
« Reply #2 on: August 01, 2008, 04:38:44 PM »
You would need to get new rims but you could go with a 255 75 R18 or a 255 80 R17 or a 255 85 R16.  You could also try:  265 80 R16 or 265 75 R17 or 265 70 R18.  Any wider than a 265 and you would exceed your 10.5 inch width limit.
« Reply #3 on: August 01, 2008, 04:56:02 PM »
With that small of a tire, I'm not sure if I'd go with a larger dia. wheel though.  That would give you less sidewall protection when aired down.
rroadkilll
« Reply #4 on: August 01, 2008, 08:56:04 PM »
285/75/16 is a 33X10.5 R16
You could look at getting a pizza cutter size from Super Swamper!!!
« Reply #5 on: August 01, 2008, 09:12:38 PM »
You might be better off looking for a 32x11.5x15 as it's more common, I know you mentioned Interco but did you look at the Narrow S.S. 34x9.5?
Why can't you run a 33x12.5? Rubbing? Stock wheels?
« Reply #6 on: August 01, 2008, 09:14:57 PM »
Also keep in mind that 34" interco's are comparable to 35" from any other brand.
willbacker45
« Reply #7 on: August 02, 2008, 11:32:17 AM »
yes i do realize that SS and interco are the same...i may just have to go with the bfg's lol
reason i want 33x10.50 and not 12.50 is i dont want to decrease my mpg all that much as my jeep is my DD
also my 31x10.50s stick out of the wheel wells alot already and i cant afford new fenders now
so thats my reasoning thanx for the help any way
« Reply #8 on: August 02, 2008, 03:24:55 PM »
If you do you won't be diappointed, they are great tires.
« Reply #9 on: August 02, 2008, 07:53:02 PM »
I run the 33x10.50's BFG AT's and like them.  Wish they made them in the MT.  When these wear out (if ever :puzzled:) I will be getting 33x10.50 SSR's.  Really like the look and performance of the 10.50's.  Could fit 35's but the TJ performs better on 33's imo.
willbacker45
« Reply #10 on: August 02, 2008, 08:07:48 PM »
i think they do make the mts now IIRC but im glad to hear u like them
« Reply #11 on: August 02, 2008, 08:35:06 PM »
The original BFG 33x10.5R15's were MT's.  The AT's used to be stuck with 33x9.5R15's, now they have both sizes for the AT's.  I've even considered 33x10.5R15's for street tires.
« Reply #12 on: August 02, 2008, 09:36:59 PM »
So are you guys saying that I can get a BFG 33x10.50 MT ???
« Reply #13 on: August 02, 2008, 09:40:54 PM »
Go to http://www.bfgoodrichtires.com/bfgapp/index.jsp
Click 'Find Tire By Size'
Then pull-down 'LT High Flotation'
Choose the size 33
Then 10.5
Then 15 and go...
All-Terrain T/A® KO
 Size:33x10.50R15/C 114R  Sidewall:RWL  MSPN:63540
    * A bold look that transforms the appearance of any vehicle
    * Maximum all-terrain traction
    * Designed to last
    * Maximized “aired-down” traction and steering control in deep dirt, mud and sand; more aggressive appearance; reduced noise; minimized hydroplaning†
    * Excellent traction and handling on- and off-road; improved traction; and decreased stone retention†
    * Exceptional bruise resistance under the tread and in the sidewall
    * Stiffer tread area for precise steering response and better cornering control; excellent puncture and bruise resistance†
    * Helps protect wheel and tire from off-road hazards, especially during aired-down driving
    * Long life and increased durability†
    * Improved ride and increased bead strength†
Warranty:Standard
   View Warranty View Tire
Mud-Terrain™ T/A® KM
Size:33x10.50R15/C 114Q  Sidewall:RWL  MSPN:78167
    * Named a 10 Most Influential product by JP Magazine
    * Unbelievable traction for deep dirt, mud and rocks.
    * Incredible rock climbing and slick surface traction†
    * Improved wheel and tire protection from off-road hazards, especially during aired down situations†
    * More even wear†
    * Reduced road noise†
    * Improved ride smoothness and tire uniformity†
    * † Compared to Radial Mud-Terrain T/A®
Warranty:Standard
Baja T/A®
Size:33x10.50R15/C 114T  Sidewall:BSW  MSPN:26444
    * Chosen by more Baja 1000 champions than all other tires combined.
    * Built for the toughest conditions on earth
    * Excellent off-road soft surface traction; more tread element edges, great side bite and lateral traction in off-road situations
    * Exceptional strength, bruise resistance and structural integrity; great strength and puncture resistance in the sidewall
    * Confident high-speed performance and handling
    * Strong lower sidewall; precise steering response and predictable cornering
    * Excellent cutting and chunking resistance; high durability
    * Distinctive appearance with black-outline serrated letters and unique Baja T/A® insignia
Warranty:Standard
« Last Edit: August 02, 2008, 09:42:04 PM by Jeffy »
