Author Topic: Regearing dana 30 and 8.8  (Read 5682 times)
enginethatcould
« on: August 04, 2008, 08:31:50 AM »
When it comes to axle I'm lost like a goose in the fog. I have a 93 2.5L with 4.10 gears. I'm currently set up on a dana 30 front and dana 35 rear. I plan on getting a ford 8.8 within the nxt month. I would like to run 35" tires but run 33" now. I will be installing a NV 3550 in two weeks. My question are;
1) What ratio should I be running?
2) What all do I need, besides the ring and pinion? Also, where is the best place to get these items?
TIA
Re: Regearing dana 30 and 8.8
« Reply #1 on: August 04, 2008, 09:38:15 AM »
Well, 4.88 will be your limit with the D-30 (don't know what the limit on the 8.8 is).  I run 4.88's with 33.10.50's and it's ok but could be better.  I am piecing together a front D-44 to match my rear D-44 so that I can go 5.38.  The 4.88 aren't quiet enough on steep hills in 4hi and 4low was to low (even prior to the tera 4:1).  You'll need to get an istall kit too (bearings, shims and seals).  Your D-30 carrier will work but don't know about the 8.8.
enginethatcould
« Reply #2 on: August 04, 2008, 09:52:35 AM »
Can you buy a carrier for the D30 that would be able to hold a higher gear like 5.13?
« Reply #3 on: August 04, 2008, 09:54:28 AM »
I dont know of anyone making any gears higher than 4.88 for the D30, and your current carrier would be the right one for 4.88...
« Reply #4 on: August 04, 2008, 01:35:34 PM »
No, your stuck at 4.88.
enginethatcould
« Reply #5 on: August 04, 2008, 03:18:28 PM »
Well...alright...scratch those plans. What would be a good axle that can hold 5.13?
« Reply #6 on: August 04, 2008, 03:24:25 PM »
D44's have 5.13 and do OK with 35's...  Not sure on the gears of the 8.8.
st.chevrolet
« Reply #7 on: August 04, 2008, 06:16:01 PM »
Yukon Gear has 5.13 gears for the 8.8. check out www.completeoffroad.com
« Reply #8 on: August 05, 2008, 10:20:08 AM »
5.38 is a great gear for the 2.5 and 5spd and 35" tires.  Don't be stuck on an 8.8, d44 rear is a good option. Isuzu Rodeo d44 rear has disc brakes and 6lug to match Waggy d44 front.
enginethatcould
« Reply #9 on: August 05, 2008, 11:50:51 AM »
What years would i need to look for d44's out of a rodeo and waggy?
« Reply #10 on: August 05, 2008, 12:02:04 PM »
Early to mid 90's Rodeo, and newer model waggy's have DS diff.
enginethatcould
« Reply #11 on: August 05, 2008, 12:12:33 PM »
Will I have to modify them much?
enginethatcould
« Reply #12 on: August 05, 2008, 12:28:12 PM »
Also, what do you mean "newer waggy"
« Reply #13 on: August 05, 2008, 12:37:38 PM »
The Wagoneer switched from pass. side diff to driver's side sometime around 1980.
Both are great axles.  I used 1" spacers on my 'Zu rear d44 to get more width, to match the Waggy front.  I'll post some pics of my setup.
enginethatcould
« Reply #14 on: August 05, 2008, 12:48:39 PM »
That's what I'm talking about!!!!!!! Looks awesome, this where i would like to be with mine. Did you do your own SOA as well?
