Author Topic: fluid for clutch resivor how to get off  (Read 1427 times)
JeffsJeep
« on: October 22, 2008, 03:49:58 PM »
hey guys, i thank you alot for all your help so far.  i have a question regarding the master cylindar.  how do you get it off?  it looks like a pin where you take it off, but it is not taken off by an alan wrench.  how do i get it off after i took the bolts off?
thanks alot, Jeff
Re: fluid for clutch resivor how to get off
« Reply #1 on: October 22, 2008, 03:54:36 PM »
thanks alot, Jeff
Once the pin is removed and the pedal is free all you have to do is undo the two bolts on the firewall.  There is glue over the area so the master will stick to the firewall even with the two nuts removed.
You should be able to remove the plastic hose as well. There is a pin that holds it in place on the MC.  The other side is a Quick Disconnect.
JeffsJeep
« Reply #2 on: October 22, 2008, 05:48:59 PM »
thanks for the help jeffy, you were correct just a pin.  you guys are awesome. :guns:
