Author Topic: dyno  (Read 4879 times)
andrew383
dyno
« on: December 16, 2008, 06:25:39 PM »
anybody had there jeep on a dyno?
andrew383
Re: dyno
« Reply #1 on: December 16, 2008, 07:00:12 PM »
reason im askin is cause im bringin the jeep back to tx with me.there is a guy here in town that has a mustang dyno.im gonna do some mods then see had the actual gains are.im gonna start off with a tune up and my modded air intake.  :weee:
Re: dyno
« Reply #2 on: December 16, 2008, 07:32:05 PM »
Dyno'ing is a really good idea to do when you want to optimize your mods.  The only problem is you can't tune the computer any.
andrew383
Re: dyno
« Reply #3 on: December 16, 2008, 07:53:56 PM »
i realize this,and its really the biggest down fall of it.
but like i stated im startin out simple with a tune up and air intake.i wanna do the bigger tb/spacer,exhaust(header/muffler),injectors(still researching),efan,and a jet chip stage 2 to finish it off.
im really interested in seeing what these mods do to the little 2.5  :nod:
Offline TahoeYJ
Re: dyno
« Reply #4 on: December 16, 2008, 09:08:36 PM »
I'd hate to hi-jack a thread, but I was wondering the other day... I've got the computer from my old engine, which I replaced with another complete 4 cyl powertrain about 5 months ago. Both are 92's so compatability isn't an issue, but is there any way to re-program my old one at all? I feel like I;m beating a dead horse here, but could I possibly send my other one to someone to "crack it open" and re-program it? This would be of course after some more modding ( ignition, injectors, TB spacer, porting...) A couple thread here and on JF have made me think about building up my old engine, I've already got the darn thing so why not do a nice little build up?  :smokes:
If I could get someone to do such a thing, would it even be worthwhile price wise? Or could I get something like the Split Second deal others have used on turbo builds? Or without boost, would it do nothing?
andrew383
Re: dyno
« Reply #5 on: December 17, 2008, 05:11:34 PM »
like jeff said there's no tuning out there for the older jeeps.jet doesnteven offer anything for the obd1.
if i "build" mine it be NA just cam/head work
Offline TahoeYJ
Re: dyno
« Reply #6 on: December 18, 2008, 06:35:47 PM »
I still think someone out there has to have the capability to re-program the ECU. Not saying I'm going to persue it, but I bet there's someone out there. That's why I mentioned the Split Second controller though, I dunno if it'd worthwhile if I'm not going the turbo route, especially for close to $300. But I'm wondering if it will help the 2.5 benefit from larger injecots and ignition upgrades... Especially if I do a mild build on my old block
Re: dyno
« Reply #7 on: December 18, 2008, 08:28:43 PM »
JET Performance tried but failed.  The problem being the YJ's computer would reset itself after taking the flash.
Offline VA_YJ
  • Now I need a CJ...
Re: dyno
« Reply #8 on: December 19, 2008, 12:17:29 PM »
What about the MAP adjusters that let you tweak the signal (variable voltage) going to the ECU?  Do they provide any benefit when used with 19# injectors, CAI, and exhaust improvements?
Offline TahoeYJ
Re: dyno
« Reply #9 on: December 19, 2008, 09:52:07 PM »
I don't know exactly how much an adjustable MAP sensor will allow you to tune, but I know the Split Second controller has it's own built-in MAP sensor and can fool the computer to allow you to tune your air/fuel ratio. It comes with it's own software, and from what I've read runs close to $300. I was thinking about going this route with my 4 popper, but I've got a good lead on a 6cyl and tranny from the same guy I got my new motor off of 6 months ago. If things don't go through, I just might end up purchasing one sometime in the future. It'll be nice to have if I ever go the turbo route  :hump:
Re: dyno
« Reply #10 on: December 19, 2008, 10:21:57 PM »
I think if you're going to do it you might as well set up a complete programmable computer to run everything.  There is a guy on the Mailing list who has just that.  He has the harness split into the main one so he can switch back to a stock computer for Emissions.  I forget what unit he was using.  Maybe FourbangerYJ remembers.
Re: dyno
« Reply #11 on: December 20, 2008, 10:24:59 AM »
Sorry Man, I don't have a clue.
Re: dyno
« Reply #12 on: December 20, 2008, 12:45:55 PM »
Ok, I remembered who it was.  He was your Klune buddy on the list.   :lol:
I asked Dave to join the forums.  IIRC, he's running an aftermarket computer and knowns a thing or two about this stuff.
Re: dyno
« Reply #13 on: December 20, 2008, 01:36:19 PM »
To be honest I have not checked the list much in the past few years. I forgot all about Dave. Hopefully he will join the forum and chime in here.
andrew383
Re: dyno
« Reply #14 on: December 20, 2008, 08:13:09 PM »
well guys the dyno thing got the ax.i got laid off friday,so the jeep isnt goin to tx :(
