Author Topic: Help! Mustang injectors screwed up my engine!  (Read 6368 times)
YJake
« on: February 21, 2009, 05:19:20 PM »
Here's the background story.
I went to the junkyard and got some of those mustang injectors and a 4.0 TB to give my little 4 banger some more get-up-n'-go.
After installing just the TB my engine ran fine, the idle was high for a few seconds then quickly dropped back down to 850RPM and leveled out.
Success!:thumbsup:
Then I added in the injectors. These caused the engine to run like crap! The engine wont idle worth a damn, it accelerates very slowly, and it redlines at 3000RPM!:thumbdown:
I then reinstalled the original injectors and the results are the same, I'm at a loss for what to do here. In order to keep the engine idling I have to give it some gas, then when it does pick up a low idle it sounds like not all 4 cylinders are firing, or they just aren't firing in any particular order. :brick:
This Heep is my DD to get to class on weekdays, Please help!
Re: Help! Mustang injectors screwed up my engine!
« Reply #1 on: February 21, 2009, 05:23:49 PM »
You could have fuel soaked your plugs, try replacing them.
Did you use new o-rings with lube when you installed the new injectors?
YJake
« Reply #2 on: February 21, 2009, 05:51:09 PM »
I will check my plugs in the morning, if fuel soaked did they burn up and need to be replaced?
And I put a little gas on the old O-rings as lube before puting the injectors on. They slid right into place.
YJake
« Reply #3 on: February 21, 2009, 07:40:37 PM »
Any other ideas folks? :confused:
lanulos89
« Reply #4 on: February 21, 2009, 10:23:35 PM »
disconnect the battery for a min let it forget so it can re learn strategy.  u might just had to do that with the 19 lb injectors too.  if it is running on what ever the stock injectors were its obv gonna run like shit till it learsn new strategy.
« Reply #5 on: February 22, 2009, 01:36:41 AM »
Did you make sure to reconnect them to the right plugs?  You can really tell if one isn't working since the engine will idle a bit loud and not make any power if you try to drive it.
Otherwise, you could have a fouled injector.  The other problem could be the plugs aren't seated properly.  Although, if you're getting a misfire then you should get a CEL right away.
YJake
« Reply #6 on: February 22, 2009, 05:42:15 AM »
A lot of people have told me that I may not have seated them correctly, does anybody have any good methods for this? I simply lubed the O-rings with gas and stuck them in there. They turn fine and feel snug in there so I figured they were fine. :confused:
I'm going to check my spark plugs today to see if I burnt one or two of them up.
st.chevrolet
« Reply #7 on: February 22, 2009, 11:48:04 AM »
JFYI  gas is not a lubricant! All you are doing to the O-rings is drying them out, which will cause damage when you install them. They won't seal properly and will eventually leak which is not a good thing on a hot engine.
st.chevrolet
« Reply #8 on: February 22, 2009, 01:14:18 PM »
I have not seen you mention anywhere in the post if you have changed the IAC valve from the 4.0L throttle body for the one from your 2.5L throttle body ????
When I first did my throttle body upgrade from a 4.0L I had similar problems with the idle, I swapped the IAC valves and the Jeep has run fine ever since.
YJake
« Reply #9 on: February 22, 2009, 05:23:55 PM »
I did in fact swap all sensors but since then reswapped and put the 2.5 TB back on with the normal injectors.
Here's what's going on as of now.
-The high amount of carbon in the exhaust is gone.
-When I start the jeep it sputters a little bit and sounds like not all cylinders are firing, then the computer kicks in and it idles at 1000RPM. However, it still accelerates very oddly when revving teh engine, and while idle it fades out to almost a stall then I can hear the computer kicking in and it smoothes out to idle at 1000RPM again.
-The check engine light comes on as soon as I hear the computer kick in to smooth out the idle after starting it.
I didn't work on it today because I have no idea what to do.  :brick:
I did however replace my passanger side seatbelt that was broke with one out of a Grand Cherokee and it now works fine.:thumbsup: (Hey.... gotta keep fixing something on it in the meantime)
« Last Edit: February 22, 2009, 05:24:28 PM by YJake »
st.chevrolet
« Reply #10 on: February 22, 2009, 05:38:14 PM »
hmm that is weird.
Well start from the basics check your fuel pressure, and all the simple things such as plugged vacuum line to the MAP sensor and so on. Not saying this is it but the symptoms you have described are not to far off of a dieing fuel pump or plugged fuel filter.
« Reply #11 on: February 22, 2009, 06:57:17 PM »
did you check the codes that are coming up with the check engine light? could help point us in the right direction
YJake
« Reply #12 on: February 22, 2009, 08:27:01 PM »
I'll be checking the codes in the morning.
As of now I had somebody suggest that I cracked a vac line while moving them out of the way for the instilation. Does a cracked vac line sound plausible for my current issues? If so, I'm not sure what kind of hose to use to replace it. :confused:
YJake
« Reply #13 on: February 23, 2009, 11:31:32 AM »
Okay so I looked for cracked vac lines and was amazed by what I found!
The hose going to what I think is the MAP sensor was completely torn in half. I'm assuming that's not good eh? :confused:
I also have a couple of cracked connector hoses. This includes one the MAP sensor vac line is attached too. I went ahead and fixed that one with a new piece of hose.
This other cracked conector I'm not so sure how to fix. I have no idea where to purchase another angles connector like this one. Anybody have suggestions?
My engine is also throwing this sequence of codes at me.
Counting the sequence befor it pauses..
3....9....6...10 (Might be off by one)
« Reply #14 on: February 23, 2009, 12:00:07 PM »
Have you tried Advanced Autoparts, AutoZone, O'Reillys, Napa, etc?  I got all of mine at Advanced Autoparts...  Just take the broken one with you so that you can compare prices.  And yes, the cracked vacuum lines will make the Jeep run like crap!
