Author Topic: Help! Mustang injectors screwed up my engine!  (Read 6381 times)
Re: Help! Mustang injectors screwed up my engine!
« Reply #15 on: February 23, 2009, 01:29:13 PM »
This other cracked conector I'm not so sure how to fix. I have no idea where to purchase another angles connector like this one. Anybody have suggestions?
My engine is also throwing this sequence of codes at me.
Counting the sequence befor it pauses..
3....9....6...10 (Might be off by one)
The engine won't run very well and should throw a code if the MAP isn't getting vacuum.
That last cracked hose connects the CCV to the manifold.  You can pick one up at the dealer for around $20.  I had to buy one last year.  That includes the rubber fitting on both ends and the plastic hose.  I bet that brass fitting might be clogged as well.
I think you're way off on the CEL codes again.
http://4bangerjp.com/forums/index.php/topic,3419.0.html
« Last Edit: February 23, 2009, 01:30:03 PM by Jeffy »
« Reply #16 on: February 23, 2009, 06:03:22 PM »
look in the windshield washer repair stuff to that will also work for vacuum lines and bends and elbows. every time I get some from kits i keep them in my tool box for stuff like that.
st.chevrolet
« Reply #17 on: February 23, 2009, 11:13:46 PM »
The severed MAP vacuum line alone could cause all the drive-ability issues you have been experiencing, figures always something simple in the end eh.
You can go to Pick & Pull for allot of those little vac lines and such, if your not up for buying the replacement parts from the dealership. Or you could build your own with the silicone hoses you can get cheap on eBay, or from local part stores for not as cheap. I bought 10 meters of the silicone hose on eBay for 10 bucks, to use for vac lines with my turbo conversion the stuff works great.
« Reply #18 on: February 24, 2009, 07:06:18 AM »
By the way, are the Jeep's hoses 4mm or 6mm?  I always forget...
tallrugbyguy
« Reply #19 on: February 24, 2009, 11:29:29 PM »
when you figure this out please post.
i have the same problem
19# injector install. lumpy idle, smooths out as it warms up, amnd poor acceleration. my vacume lines seem intack......... tried restarting the computer, no schange.
YJake
« Reply #20 on: March 01, 2009, 10:16:07 PM »
Fixed all vac lines and etc. Still running bad but have narrowed everything down.
New thread.
http://4bangerjp.com/forums/index.php/topic,6312.0.html
