Author Topic: Jeep won't start  (Read 6141 times)
93yjFirstJeep
Jeep won't start
« on: October 05, 2009, 07:41:16 PM »
So my jeep ran out of gas the other day, so i pull over, walk to the gas station, buy a can and gas, put it in the jeep, and still no start. I noticed the fuel pump isn't priming. Is this for sure the fuel pump?
Re: Jeep won't start
« Reply #1 on: October 05, 2009, 07:47:57 PM »
can you hear the pump?
do you have any pressure (you can carefully press the schraeder valve to check) or is anything coming out off the return?
« Reply #2 on: October 05, 2009, 08:56:24 PM »
are you sure you got enough gas in for it to start? and you may have clogged the fuel filter with crap from running it dry... but that wouldn't prevent it from priming as it would get up to pressure.. just not at the fuel rail (i could be wrong).
DodgeMudder
« Reply #3 on: October 06, 2009, 09:57:48 AM »
How long did you leave the pump on after it ran out of gas?
My first thought if the pump isn't running at all is to check the fuse, might have over heted the pump popping the fuse from it running w/ gas.  Otherwise I would say it's the pump.  (disregard all of this is you hear the pump come on at all when the key is first turned on)
93yjFirstJeep
« Reply #4 on: October 06, 2009, 03:52:40 PM »
It didnt actually run out of gas, it  just acted like it
« Reply #5 on: October 06, 2009, 04:46:20 PM »
Best way to check is check the fuel pressure at the rail.  First check is as simple as pressing the valve, and if fuel comes out, the pump is working.  On mine, there was nothing coming out when the fuel pump died on me...
« Reply #6 on: October 06, 2009, 07:56:46 PM »
Try pressing the accelerator while cranking.  I know it's fuel injected and you shouldn't need to, but it has worked for me in the past.
93yjFirstJeep
« Reply #7 on: October 09, 2009, 09:46:54 AM »
Alright  :brick:
SO i dropped the tank and replaced the fuel pump, in a college dorm parking lot, without a jack, and with about 5 gallons in the tank. Real fun.
Still no start, however the fuel pump is priming now
wtf?
fuel filter maybe?
« Reply #8 on: October 09, 2009, 10:47:10 AM »
Go through the paces;
Check that you have spark (careful not to shock yourself!)
Check that you have fuel pressure (at the rail)
I would bet it's one or the other...
« Reply #9 on: October 09, 2009, 10:54:14 AM »
maybe check this ^
93yjFirstJeep
« Reply #10 on: October 09, 2009, 02:07:58 PM »
ya, checked it and no pressure at the rail
« Reply #11 on: October 09, 2009, 02:47:25 PM »
Have you checked the fuel filter by any chance?  It may be clogged up, and if so, this could be why the pump was not priming (there was already pressure after the pump).
« Reply #12 on: October 09, 2009, 03:07:49 PM »
x2
93yjFirstJeep
« Reply #13 on: October 09, 2009, 06:37:17 PM »
Replaced the fuel filter today, and still no pressure
93yjFirstJeep
« Reply #14 on: October 10, 2009, 03:41:23 PM »
So i cracked the fuel line before the filter to see if i had pressure, and i dont. The pump is priming when i turn the key, but no fuel is coming through the line. I'm getting desperate. Any help would be great  :brick:
