Author Topic: 4Banger Jeep Speed (Ha! :)  (Read 31315 times)
TrailsLessTaken
Re: 4Banger Jeep Speed (Ha! :)
« Reply #15 on: October 21, 2009, 11:38:14 AM »
I think mine tops about about 65 with 4.10's and 35's, it might be able to hit 70 if the wind is with it
« Reply #16 on: October 21, 2009, 01:44:10 PM »
is it 65 what your speedo shows or based on gps or adjusted speedo reading?
« Reply #17 on: October 21, 2009, 04:24:50 PM »
I'm talking gps. my speedo reads faster then your actually going now with the 4.88s not much out but still go by my gps.
« Reply #18 on: October 21, 2009, 04:30:22 PM »
yeah, gps is good - i thought you said 35s and 4.10 (actually that was TrailLessTaken), that's why i was asking - but from what i know even with 4.88 and 35s should still show less than what your real speed is (unless you changed your speedo gear) - my understanding was that 33s and 4.88 is close to stock speedo reading
« Reply #19 on: October 21, 2009, 04:47:38 PM »
Not correcting your speedometer will have an effect on performance as the PCM uses the vehicles speed to adjust the timing and I believe the fuel curve.  Not to mention its a cheap fix.
  • 4BangerJP.comŪ Donator
« Reply #20 on: October 21, 2009, 10:52:24 PM »
Ah, very interesting.  Didn't think of that.
« Reply #21 on: October 21, 2009, 11:41:39 PM »
Is the PCM adjustment to the timing/fuel curve pegged to the speed as shown on the speedometer or to the actual vehicle speed?  My speedometer reads about 5mph slow vs GPS readings.  I'm figuring the PCM adjustment to the timing/fuel curve is pegged to the speed shown on the speedometer.  I'' have to get this adjusted
« Reply #22 on: October 21, 2009, 11:47:38 PM »
The PCM reads speed by way of the VSS which is tied into the speedometer.
http://4bangerjp.com/forums/index.php/topic,731.0.html
« Last Edit: October 21, 2009, 11:48:19 PM by Jeffy »
« Reply #23 on: October 22, 2009, 12:28:16 PM »
It's a 15 min job and is dirt cheap, mine's been corrected 3 times now for the tires I've run. Hard to believe anyone would deal with the wrong speedo gear as cheap and simple as the fix is.
« Reply #24 on: October 22, 2009, 01:08:44 PM »
who carries the gears? i am fine now but i want to get a 39T in case i ever go to 35s. and how much is one if you remember.
« Reply #25 on: October 22, 2009, 01:31:43 PM »
Try the Dealer.  They are usually under $30.
« Reply #26 on: October 22, 2009, 02:49:46 PM »
Dealer for sure, my last one was $22-23 IIRC
« Reply #27 on: October 22, 2009, 04:38:31 PM »
mine isn't far off. maybe 5-7km's with the 33's with 4.88's.
don't think it would do much to my timing on my old YJ lol being stationary distributor. the tj's with coil over plug would prod adjust for speed and various other conditions.
« Reply #28 on: October 22, 2009, 05:13:03 PM »
Timing isn't controlled by the distributor.
pioneer4x4
« Reply #29 on: October 22, 2009, 05:56:23 PM »
hate to butt in, but if i follow you guys correctly the ecu adjusts from vss inputs so in my 86 xj with no vss, just regular old cable driven type, it wouldnt matter (to ecu) if my speedo gear is wrong tooth count.
