Author Topic: need power steering help  (Read 2812 times)
AC3tj
« on: March 21, 2010, 04:37:04 PM »
i was trying to replace the seals on my power steering because it is leaking from the pitman arm seal but i can get the pitman arm off the output shaft.
i tried a puller i hit it with a hammer in every direction i can think of but i can t get it off.
please help with any sugestions.
Re: need power steering help
« Reply #1 on: March 21, 2010, 04:58:27 PM »
Put the pitman arm pulled on and crank it till it's good and tight.  Then take a 3lbs sledge or better yet two and smack the part that holds against the splines from both sides.  If you only have one sledge then jsut smack it a few times then crank the puller tighter then repeat.  It's a good idea to leave the nut on loose so the pitman arm doesn't fall off.
Offline oldjeep
    • www.Oldjeep.com
« Reply #2 on: March 21, 2010, 05:20:31 PM »
Since you are replacing the seal anyway - take your propane or MAP torch and warm up the pitman - leave the pitman puller on it with some tension.
Chuck P
94 YJ - gone
98 ZJ - sons truck
97 TJ - daughters project
www.oldjeep.com
« Reply #3 on: March 21, 2010, 05:26:11 PM »
That's what I did. It came off faster than a prom dress! :naughty:
AC3tj
« Reply #4 on: March 21, 2010, 05:45:26 PM »
good try but it is still on any other suggestions
AC3tj
« Reply #5 on: March 21, 2010, 05:46:42 PM »
i think it needs to get hotter quicker but my torch is to small i will get a bigger one tommorow
Offline oldjeep
    • www.Oldjeep.com
« Reply #6 on: March 21, 2010, 05:53:51 PM »
Don't need a big one, regular $12 hardware store torch is fine.  Just hold the flame on for a while
Chuck P
94 YJ - gone
98 ZJ - sons truck
www.oldjeep.com
« Reply #7 on: March 21, 2010, 06:54:50 PM »
i had the steering box off and i put the pitman on a vise (one side of the part that goes on the shaft) and hit it with a hammer on the other side. once i did that came off with the puller.
« Reply #8 on: March 22, 2010, 09:27:25 AM »
If you are not replacing the sector shaft you don't need to remove the pitman arm.
AC3tj
« Reply #9 on: March 22, 2010, 06:07:13 PM »
thanks for all the tips i got it off and put the new seals on and its back toghether and runs great.
thanks again
