Author Topic: Crankshaft kit for 88 4.0  (Read 4211 times)
bammerman
« on: April 06, 2010, 04:26:51 PM »
Guys I am having a hell of a time finding one of these.  Can any of you offer assistance on where to buy one?
Re: Crankshaft kit for 88 4.0
« Reply #1 on: April 06, 2010, 05:10:07 PM »
what do you mean by a kit - the crankshaft itself?
« Reply #2 on: April 06, 2010, 05:34:37 PM »
Looking to do a stroker?
« Reply #3 on: April 06, 2010, 06:23:56 PM »
Can you even do it on a Renix engine?
« Reply #4 on: April 06, 2010, 07:02:05 PM »
Maybe not. It's the 258 crank and rods that goes into the 4.0 to make the stroker so :confused:
Maybe the bottom end is bad in the motor he has?
bammerman
« Reply #5 on: April 06, 2010, 07:46:36 PM »
No we were going to turn the crank, but I figured with the machine shop prices of $200.00 to do it I could just buy a kit for a brand new one right off the bat.
« Last Edit: April 06, 2010, 07:47:00 PM by bammerman »
YJmechanic
« Reply #6 on: April 06, 2010, 07:50:14 PM »
i thought you said this thing was like new?  i wouldnt be taking anything off the crank if its in that good of shape
« Reply #7 on: April 06, 2010, 08:52:11 PM »
did you measure it? maybe you don't need to turn it (or grind it to be more specific) - buy some gap measuring stripe gauges (check the FSM for exact specs) - you might only need bearings.
bammerman
« Reply #8 on: April 07, 2010, 09:14:47 AM »
To be honest I am not sure what the mechanic is doing.  He just told me to get prices.  :confused:
« Reply #9 on: April 07, 2010, 09:59:12 AM »
Check your local CL lists. I sold a 4.0l long block with manifolds rather quickly for $175. I didn't do a compression check and many of the acc were removed.
« Reply #10 on: April 07, 2010, 12:20:15 PM »
This is for a Renix 4.0L which uses a different cam profile then the HO.
« Reply #11 on: April 07, 2010, 12:24:47 PM »
is the crankshaft different between the 2?
bammerman
« Reply #12 on: April 07, 2010, 12:29:24 PM »
Talked to my mechanic.  said if we are going to turn/grind whatever you call it on the crankshaft that it might cost $200.00.  Said if the kit was cheaper to just do that if it is needed.  he is currently just cleaning up everything on the engine.  It is tore down to nothing right now.
« Reply #13 on: April 07, 2010, 12:30:44 PM »
Whoops, read it as cam not crank but there are differences there was well.  Bearing and journal ports are different.  I think you need to use the block's bearings and not the cranks.
« Last Edit: April 07, 2010, 12:41:08 PM by Jeffy »
« Reply #14 on: April 07, 2010, 01:01:28 PM »
i just looked and the crank main bearing part #s are different between 88 and 91-95 4.0L, not sure what the differences are (could be like you said the block is different).
