Author Topic: Lunch on the trail  (Read 4892 times)
Lunch on the trail
« on: May 08, 2010, 01:42:37 PM »
So what is for lunch when your wheeling?
Normally I pack a PB&J,Pringles,fruit of some sort banana or apple. Lots of diet soda and a few bottles of water and a Monster!
(yes I'm bored) ::)
Re: Lunch on the trail
« Reply #1 on: May 08, 2010, 02:23:22 PM »
Since I work nights, a monster is a must have for Saturday wheelin trips
« Reply #2 on: May 08, 2010, 02:47:13 PM »
Usually some pringles and a coke super big gulp from circle k.
« Reply #3 on: May 08, 2010, 03:41:46 PM »
No manifold burritos?
« Reply #4 on: May 08, 2010, 03:45:03 PM »
or manifold :spam: ?? ? :)
« Last Edit: May 08, 2010, 03:45:58 PM by 1995yj »
« Reply #5 on: May 08, 2010, 04:50:38 PM »
we either have chicken-bakes on the manifolds or hotdogs.. i found the chicken bakes are perfect size to set on top on the radiator and the hood comes down and holds them in place without totally smashing them. so 2 on the radiator, one on intake manifold against the head and one goes in-between the power steering pump bracket and the engine / exhaust manifold. flip / rotate spots after 15-20 minutes. then when you start to smell burning chicken bake find a place to eat and wala nice hot chicken bake. the burning smell will come form the one that directly touches exhaust manifold and it will only-be slightly burnt, with burnt portion easy to remove....
http://http.cdnlayer.com/smoola/00/00/62/0dbbaba28a22d402_m.jpg - beats a cold sandwich any-day.
this is all with tbi, for mpfi the intake manifold wont be as warm and your ps pump is totally different. but considering how hot everything under the hood gets at low speed they should eventually cook just about anywhere.
the Flathead 4 go-devil motor is preferable as it has more surface area where you an cook stuff.
pringles are relay good for on the trial as the can prevents crushing. we usually fill the can with other chips after the first day...
« Last Edit: May 08, 2010, 04:52:26 PM by chardrc »
TrailsLessTaken
« Reply #6 on: May 08, 2010, 09:17:58 PM »
Last trip I got some fried chicken from wally world, pringles and some grapes and cheese.  I havent tried any of the manifold cooking but I wouldnt mind giving it a shot sometime
« Reply #7 on: May 08, 2010, 09:33:30 PM »
I'd probably buy one of these.
« Last Edit: May 08, 2010, 09:35:57 PM by Jeffy »
« Reply #8 on: May 08, 2010, 09:36:43 PM »
Flippin cool, who knew a cig lighter had enough current.   :drink:
« Reply #9 on: May 08, 2010, 09:40:03 PM »
Well, I know Alton Brown used on on Feasting on Asphalt and it blew a fuse in one truck.
  • Poseur Extraordinaire®
« Reply #10 on: May 09, 2010, 03:50:43 PM »
I'm back off bread and sugar, so it looks like it will be salami and provolone wrapped up with a little spicy mustard and maybe pickle....water for this trip.
Have lost 15 lbs. in the past few weeks and want to keep it going.
Sine Deviance
« Reply #11 on: May 10, 2010, 02:50:54 PM »
Cooking stuff on the manifold... just wow. I've gotta try that. Can I cook ribs and such on it too?
« Reply #12 on: May 10, 2010, 02:58:29 PM »
Usually a couple of ham and cheese sandwiches, some cookies, about a gallon of water, and three beers.
« Reply #13 on: May 10, 2010, 03:06:44 PM »
as long as it fits and you can figure out a way to know when they are done before being totally burnt. its nice to have precooked things so you don't have to worry about them fully cooking. but the more times you cook something this way the better you will be able to hone in on the amount of time necessary. a big factor is not using too much aluminum foil and to rap it tightly so that all the heat doesn't get blocked by the foil.
« Reply #14 on: May 10, 2010, 03:20:38 PM »
it's not really anything new.
I think this is an interesting one as well.  I can only think you might be able to put it in front of the cat.  They're used on snowmobiles.
Here's a rack in my friends JK.
« Last Edit: May 10, 2010, 03:25:17 PM by Jeffy »
