Author Topic: Flex-a-lite fan installation help please  (Read 3822 times)
Offline Lu
« on: June 22, 2010, 08:27:32 PM »
So, I just got my electric fan today and was super excited to install it but frankly, I'm stuck, and it's only been 15 minutes.  It says I have to find a place to mount the control module.  Where should I do that?  Do I need to drill into the fender well or something or just zip tie it on anywhere there's room?
Any help or suggestions from anyone who has installed this fan would be appreciated.  Not only with regard to the control box but any other advice would be handy.
I may not be able to get anywhere quickly, but I can get most anywhere I please.
Re: Flex-a-lite fan installation help please
« Reply #1 on: June 23, 2010, 01:14:01 AM »
If you search for 'electric fan', you'll find a couple of our write-ups for our installs.  I've gone through two because I went ghetto initially and then upgraded to gold plated ghetto.
Here's a few of what I found in the board...
http://4bangerjp.com/forums/index.php/topic,4913.0.html
http://4bangerjp.com/forums/index.php/topic,2544.0.html
I've mounted a electric thermostat controller to the inner fender, ran it to keyed iginition from the firewall off a relay plug for the torque lockup, some photos are in the posts at the bottom.
Here's some of my posts...
http://4bangerjp.com/forums/index.php/topic,8497.0.html
http://4bangerjp.com/forums/index.php/topic,8496.msg70456.html#msg70456
Offline Lu
« Reply #2 on: June 25, 2010, 08:31:50 AM »
So you DO have to drill into the fender well to mount the thing?
« Reply #3 on: June 25, 2010, 09:41:20 AM »
You can drill or just use some self tapping screws.  Drilling is easier.
« Reply #4 on: June 25, 2010, 02:00:11 PM »
What fan, specifically are we talking about here?  It doesn't sound like the Mustang/Wrangler Flex-a-lite fan.
Offline Lu
« Reply #5 on: June 26, 2010, 09:32:12 AM »
It is the wrangler flex-a-lite fan.  I am having a little difficulty because the instructions are a tad cryptic
Offline Lu
« Reply #6 on: June 29, 2010, 10:06:22 PM »
I'm having difficulty figuring out what to hook it to so the fan only runs when the ignition is on.  I hooked it up to the battery since it is always hot and everything works perfectly I just don't want the fan to keep running while the ignition is off.  So what are my options?
TrailsLessTaken
« Reply #7 on: June 29, 2010, 10:16:03 PM »
You need to find a wire that sends power out when the key is in the on position, the one for the radio would be an easy one to access or just wire it up to a switch and turn it on an off manually.  Some of the guys on here are running a fan controller.  Jfrabat has one i believe, if you check his build thread he has info on what type it is
« Reply #8 on: June 29, 2010, 11:25:54 PM »
On my 95 yj, it's a white wire with a yellow stripe (At the PCM, on the relay for the torque converter lock up, etc.. ).  I can find it all over my harness under the hood.
« Last Edit: June 29, 2010, 11:26:27 PM by 1995yj »
  • Poseur ExtraordinaireŽ
« Reply #9 on: July 01, 2010, 08:16:04 AM »
I wired mine to the cigar lighter....that way I was close to the steering column when mounting the on/off switch.
  • Chief Squirrel BlowerŽ
« Reply #10 on: July 01, 2010, 08:40:38 AM »
i think that one has 12v while cranking as well (fused ignition switch output), should be one that only has 12v key on so it won't spin the fan when you crank - the cig lighter would be a better choice imo (like Mozman said)
« Reply #11 on: July 01, 2010, 11:31:50 AM »
Yep...my fan won't kick up on start-up until the Jeep is actually running.
TrailsLessTaken
« Reply #12 on: July 01, 2010, 04:15:12 PM »
Thats not a bad idea, although mine will only turn on if the key is in the on or accessory position but its loud enough that you dont forget to turn it off if the jeeps not running
« Reply #13 on: July 03, 2010, 02:59:43 PM »
Good to know.
« Reply #14 on: July 04, 2010, 06:35:23 AM »
well...mine will go on in the accessory position as well...... :confused:...but like all accessories, it won't come on as the engine is trying to turn over.
